What transmission? - Pontiac GTO Forum
post #1 of 5 (permalink) Old 07-24-2017, 09:53 PM Thread Starter
What transmission?
Hey y'all!
Getting back at the 1973 GTO. Bit of history, when I bought it the PO said he didn't remember what kind of tranny itnis but its not original, I'm assuming a 350 auto tranny but I don't know. He said it would probably need at least new seals. We put 3 quarts of atf in and got it driving, but the car bogs out when put in drive or reverse, and randomly will go or will not go. 3 days later i have a lovely red pool under the car. So...
Does it sound like the tranny is toast? Worth messing with? I love to mess with old stuff but have yet to do any tranny work on anything so totally clueless here.
I'm considering buying a turbo 400 tranny off craigslist for it for $200-400. Would that work with the non original Pontiac 350 motor that's in the car? Or is that a totally crazy idea?
Need to save up some for project funds and those will be limited so trying to keep it as cheap as possible.
Any info, thoughts and opinions will be greatly appreciated!
Tracto-man is offline
post #2 of 5 (permalink) Old 07-24-2017, 10:26 PM
Quoted: 66 Post(s)
Pretty sure that the TH400 was the only auto trans available in a '73 GTO.
"...I'm considering buying a turbo 400 tranny off craigslist for it for $200-400. Would that work with the non original Pontiac 350 motor that's in the car? Or is that a totally crazy idea?..."
If you get a good one, it should work. But you need one for a Pontiac, Olds, or Buick. If you buy a Chevy TH400, you'll need an adapter plate, in order to bolt it up to the Pontiac 350 engine.
Also need a short tail version. Lots of big cars used a long tail TH400. A long tail would require the crossmember to be farther back, and a shorter driveshaft.
Also, the fluid might be leaking from the front seal, rear seal, dipstick tube seal, or pan gasket.
bigD is offline
post #3 of 5 (permalink) Old 07-27-2017, 02:03 PM Thread Starter
Thank you! That's what I needed to know! Noe to find a tranny...
post #4 of 5 (permalink) Old 07-27-2017, 06:02 PM
Quoted: 31 Post(s)
[QUOTE=Tracto-man;807369]Thank you! That's what I needed to know! Noe to find a tranny...[/QUOTE
Where do you live?
dd68gto is offline
post #5 of 5 (permalink) Old 07-27-2017, 09:31 PM Thread Starter
Mid MI, half hour south of Lansing
Transmission help CptTheAlex 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 6 10-15-2015 09:32 AM
Can't get transmission all the way in Mikes145 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 19 06-16-2015 09:41 AM
Transmission OUT Mddrummer911 Drive train, suspension, alignment and brakes. 10 02-07-2012 08:28 AM
Transmission Help!!!! josejesm 2004-2006 GTO General Discussion 3 01-31-2012 04:28 PM
Transmission gone meg30_68 Drive train, suspension, alignment and brakes. 10 01-15-2008 07:18 AM
