Will a 79 pontiac motor and transmission fit in 70 gto - Pontiac GTO Forum
post #1 of 4 (permalink) Old 06-12-2013, 05:13 PM Thread Starter
I have found a 79 firebird motor and trans that runs and good trans for $400 owner said its a 350 or 305 he beileves with under 65xxx miles will this be a good fit in my 70 gto without fabricating he said the motor was in a 69 firebird.
codywp is offline
post #2 of 4 (permalink) Old 06-12-2013, 06:31 PM
If it's a real Pontiac, it should fit fine. Would it be possible for you to get all the numbers off it? (Date code, casting code, etc) to id exactly what it is?
Google "pontiac engine codes" to get information on the locations of the various codes and how to read them.
post #3 of 4 (permalink) Old 06-12-2013, 08:34 PM
jmt455's Avatar
Make sure you're getting a Pontiac engine; they built Firebirds with Chevy small blocks (305 and 350).
1968 Pontiac GTO
2008 Pontiac G8 base
jmt455 is offline
post #4 of 4 (permalink) Old 06-13-2013, 12:49 PM Thread Starter
Ok thanks and i think thats what motor it has but will be getting the numbers later today
codywp is offline
Transmission bolt up to my motor Jaje14 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 0 11-08-2012 07:01 AM
GM (Pontiac) manual 3 speed Transmission Josh.AZ.GTO 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 6 12-09-2010 07:06 AM
trying to ID a pontiac motor 7ft stew 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 14 04-02-2010 03:27 PM
Fs: Pontiac 421 Ho Motor cfPontiac 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 05-08-2008 09:11 PM
