will a 8.2 10 bolt posi unit out of a chevy fit in a bop 8.2 rear? - Pontiac GTO Forum
post #1 of 9 (permalink) Old 08-24-2012, 05:52 PM Thread Starter
im about to but a posi unit for my tempest, my tempest has 2.56 non posi 8.2 buick olds pontiac rear in it, the posi unit is out of a 65 chevelle 8.2 10 bolt, the guys selling it cause he needed one that uses c clips and this one is for bolt in axals, the buick olds pontiac ones are bolt in so will this fit my rear? also its out of a 65 and my car is a 66.
danthepontiacman is offline
post #2 of 9 (permalink) Old 08-24-2012, 06:10 PM
Quoted: 119 Post(s)
Depends on the gear ratio. If the posi unit in question is a 2 series carrier, for the 2.56 and 2.78 gear ratios, should be ok. But it's probably for a more common 3 series gear, like a 3.08, 3.23, 3.36, etc...and it won't work. The 2 series carriers use a very thin ring gear and a huge pinion gear. The other carriers, 3 and 4 series go the other way: thick ring gear and small pinion gear.
post #3 of 9 (permalink) Old 08-24-2012, 07:10 PM Thread Starter
well the unit has the 3.36 gears with it so id be changeing the hole thing if that makes a diffrence
post #4 of 9 (permalink) Old 08-25-2012, 10:56 AM
Quoted: 119 Post(s)
Try to get The entire rear end, and that way, you can bolt it in after checking it out. Much less likely to have issues that way. But yeah, if you swap the carrier assemblies, no worries. If he needs a core to build, (axle housing) just swap him.
post #5 of 9 (permalink) Old 08-25-2012, 11:10 AM
jetstang's Avatar
I'd check the application on Summit, and see if it's the same part number. I am pretty sure it's not. I put a 66 Chevelle rear end in my 70 Lemans, it fit great, but I did have to get a conversion U joint, chevy's is bigger, so the pinion is probably bigger also I assume.
Burning rubber since 1982!!
jetstang is offline
post #6 of 9 (permalink) Old 08-25-2012, 12:00 PM Thread Starter
i cant find the chart your talking about on summit? whats it under? id love to buy a hole rear end but i cant aford the shipping on one or the price for that matter, im stretching my dollers to get the posi chunk. what would you have to do to adapt it to a pontiac?
post #7 of 9 (permalink) Old 08-25-2012, 12:11 PM Thread Starter
is it possible a bop rear was in the chevelle? i just wonder cause i was told that all the chevy units used c clips
post #8 of 9 (permalink) Old 08-26-2012, 11:51 AM
Quoted: 119 Post(s)
Dan, that's what I thought. All the Chev rear ends used the clips. The fact that it is set up like a BOP tells me that it probably is. Good luck with it...
post #9 of 9 (permalink) Old 09-04-2012, 02:08 PM Thread Starter
thanks its on its way to me, i hope going from the 2.56 gears in my tempest to the 3.36 ones will give it more of a kick, later ill put a overdrive in it witch give me a lower first so that help too. one thing at a time.
10 bolt posi chevelleman68 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 5 04-28-2011 10:44 AM
Is the 10 Bolt 8.2 BOP Carrier the same as Chevy 10 Bolt? mighty454 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 6 04-21-2010 04:30 PM
69 GTO 10 bolt non-posi convert to 12 bolt posi AzStateFan 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 0 09-12-2009 05:34 PM
Shouldn't my 455 with 12 bolt have a posi? 70455goat 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 1 08-11-2008 08:18 AM
