z bar/ clutch return spring ???? - Pontiac GTO Forum
post #1 of 3 (permalink) Old 03-31-2019, 08:01 PM Thread Starter
Hey guys,
I'm working on converting my auto 66 gto to a 4 speed and have a couple questions here.
I got what I thought and appeared to be a used z bar... however it doesn't have a hole for the clutch return spring... does anyone know how high up the hole for this needs to be drilled on the z bar? and I also cant see anywhere on the frame or firewall where the other end of the spring would attach to. do I need to drill out a location for this as well??? If anyone has pictures or can help with this as well that would be much appreciated.
God, Country, Cars
gmjunkie is offline
post #2 of 3 (permalink) Old 04-01-2019, 05:23 AM
GTOJUNIOR's Avatar
Quoted: 68 Post(s)
This is off my '66 OHC but would apply to GTO as well.
The SMALL Spring from Fork to Z is set at aprox 1.5" above rod pivot point on Z.
The LARGE Spring From Z to Floor Brace (Not Frame)is set from factory in a hole aprox 2" above Body Bushing.
I hope this makes sense,Helps.
Cheers.
Name:	CLUTCH LINKAGE 66.jpg
ID:	118351   Click image for larger version
ID:	118353   Click image for larger version
ID:	118355   Click image for larger version
ID:	118357   Click image for larger version
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #3 of 3 (permalink) Old 04-01-2019, 10:00 AM Thread Starter
Thank you!
God, Country, Cars
gmjunkie is offline
68 GTO Clutch Return Spring Bracket bgumpper 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 05-01-2016 11:45 PM
66 Clutch Return Spring?? leeklm 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 03-12-2013 11:40 PM
Z-Bar Return Spring Bracket MaL 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 07-14-2011 10:36 AM
Clutch Pedal return spring Sloan66 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 11-01-2010 10:47 AM
65 clutch pedal return spring ponchonorm 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 08-25-2009 08:05 PM
