1967 door trim removal question. - Pontiac GTO Forum
 1Likes
  • 1 Post By cij911
post #1 of 2 (permalink) Old 10-07-2019, 09:05 PM Thread Starter
RMTZ67's Avatar
Quoted: 78 Post(s)
I was needing to remove this upper door trim to fix those small dents. Does anyone have one off and can tell me how to remove it. I don't want to do more damage to it. Thanks
RMTZ67 is online now
post #2 of 2 (permalink) Old 10-08-2019, 08:34 AM
Quoted: 153 Post(s)
The trim is screwed to the door. You'll need to roll down the window and look at the rubber / felt piece for small phillip screw heads. Given the age of the car, I have no idea how many you'll have but I am guessing at least 5. The front screws are the most challenging to get to. Good luck
PS - DON'T DO WHAT OTHER TOLD ME TO DO WHICH WAS JUST PULL IT UP. IF IT DOESN'T COME OFF EASILY, THERE IS STILL A SCREW SOMEWHERE ALONG THE TRIM.
RMTZ67 likes this.
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is offline
