1967 GTO fender lower at cowl not straight - Pontiac GTO Forum
post #1 of 3 (permalink) Old 06-05-2015, 05:43 AM Thread Starter
My 67 GTO fender, where it sits on the cowl, by the lower bolt, is not flush. At the wheel opening, the fender is up about 1/2 inch. When I put a straight edge across the rocker to the wheel opening, it is not flush over lower fender. Any idea how to fix this so the lower trim will sit flush?
Jack
67 GTO
xkeots is offline
post #2 of 3 (permalink) Old 06-05-2015, 01:08 PM
Is the lower fender out too far? Or in to far?
post #3 of 3 (permalink) Old 08-01-2015, 02:02 PM Thread Starter
Both fenders sit perfectly spaced with both doors. But at the bottom of both at the tires, they go outwards. I was told to loosen bottom bolt, turn front wheels and put a 2x4 in, resting on the lower fenders and push till they are straight. They bend at the center where the cowl/fender rear support is. A straight board (2x4, yard stick, even the lower moulding does not sit straight across the rocker panel to fender.) I am at a loss. Now from loosening the lower bolt, the fenders now are not giving me a nice space along the doors. I hope I don't have to remove hood as I now have no helper.
Jax
xkeots is offline
1967 GTO - Steering Column Lower Bearing Replacement Beefcake77 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 0 10-07-2014 08:31 PM
1967 GTO 400 HO cowl tag turbopedro 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 9 05-12-2014 05:48 PM
1967 GTO lower sill moldings how to polish ? fiesta62 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 5 05-04-2014 01:02 AM
Lower cowl panel DrBoeing 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 12 06-17-2011 01:29 PM
