1968 Radiator Core - Pontiac GTO Forum
post #1 of 8 (permalink) Old 01-27-2018, 11:12 PM Thread Starter
1968 Radiator Core
Hi new to forum question i got a body kit from ames (1968 gto convertible) and i am trying to figure out how the body mounts get mounted to the frame. the center of the mount does not fit thru the hole in the core. Am i installing them incorrectly? Does anyone have a picture of how they are installed. Please help
Onsetper is offline
post #2 of 8 (permalink) Old 01-28-2018, 10:16 AM
Quoted: 79 Post(s)
Does this help?
Sent from my XT1585 using Tapatalk
Shake-N-Bake is offline
post #3 of 8 (permalink) Old 01-28-2018, 11:38 AM Thread Starter
the rubber around the bottom bushing is too wide to fit into the core.
Onsetper is offline
post #4 of 8 (permalink) Old 01-28-2018, 11:39 AM Thread Starter
thanks it does help. driving me crazy.
Onsetper is offline
post #5 of 8 (permalink) Old 01-28-2018, 11:44 AM
Quoted: 79 Post(s)
Here are some photos of how it should look. Apologies for the messy parts....am block sanding the car today and that dust gets everywhere....
post #6 of 8 (permalink) Old 01-28-2018, 12:37 PM
Quoted: 13 Post(s)
When I purchased the body kit for my 67, the radiator core support did not come with it. It was a separate kit.
Colorado67GTO is offline
post #7 of 8 (permalink) Old 01-28-2018, 12:56 PM Thread Starter
the rubber around the spacer is too wide I am just going to cut the rubber and fit the metal pacer into the core
Onsetper is offline
post #8 of 8 (permalink) Old 01-28-2018, 04:45 PM
Quoted: 79 Post(s)
How big is the hole in your core support? I purchased the kit from Ames as well and the hole was quite a bit larger than the rubber collar....probably about 1/8" clearance. When you assemble the front clip....you may need some play in that hole so you can move the core supper side to side. I would enlarge the hole vs trimming the rubber. Are you using a 68 V8 core support?
66 radiator core support tspring 1964-1974 GTO's and Parts Wanted 5 03-30-2019 05:00 PM
Electric fans and 4 core radiator GTO1965 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 06-15-2014 12:20 PM
Radiator core support cfd2bc 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 08-23-2012 11:49 AM
69 Radiator core support help!!!! 369GTO 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 10-10-2010 08:39 PM
65 radiator core support mounting trimfixer 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 03-10-2010 10:38 PM
