1969 GTO inner fender removal - Pontiac GTO Forum
post #1 of 8 (permalink) Old 01-14-2017, 09:44 PM Thread Starter
JPJ
I'm doing body bushings on my '69 GTO convertible, and understand that the inner fenders need to come out to reach the nuts behind them. I saw several people online say you could remove the inners on A-bodies (not specifically Pontiacs) without taking off the outer. I started on the right side and have all the fasteners removed. It's like some kind of puzzle now -- it's like I can get it really close to coming out, but maybe 1/4" away from clearing somewhere no matter which way I try to take it out. I tried using nylon pry tools to flex the gaps larger but still not there. Have already scratched the upper control arm and top of the frame that were detailed, so hoping there is some trick I'm missing to get this thing out more easily. Confirmation that the inner can come out this way and any suggestions would be greatly appreciated.
JPJ is offline
post #2 of 8 (permalink) Old 01-15-2017, 07:06 AM
I've never tried it but, like you, have only "heard it was possible". I've also heard it was very tricky to do. Given that you're doing this to replace the body bushings, I think I'd just "bite the bullet" and remove both the inner and outer fenders. Why? because the fronts of the fenders connect to the core support, so when you lift the body a little to get the bushings in and out, the fronts of the fenders aren't going to move. I'd be concerned about bending something you don't want bent. Plus, if you're replacing body bushings, are you replacing core support bushings too? If your body bushings have "flattened" and replacing them lifts the body a little, you may find that afterwards you won't be able to get the gaps along the front edges of your doors straight if your core support bushings have flattened also.
post #3 of 8 (permalink) Old 01-15-2017, 09:22 AM
Fender is going to have to come off.
post #4 of 8 (permalink) Old 01-15-2017, 09:49 AM
Muscle_Cars_Only's Avatar
When I did mine several years ago , I had to remove the fenders.
Muscle_Cars_Only is offline
post #5 of 8 (permalink) Old 01-15-2017, 09:52 AM
On my '70 when my heater core needed replaced and the cover access to the one bolt was needed my buddy removed my inner fenderwell. He had no issues. Took finesse and patience which I lack to get out then back in. He actually had no issues and for him was quite simple.. so it can be done. That was on the passenger side, the one on the driver's side does not have the room it appears.
post #6 of 8 (permalink) Old 01-15-2017, 05:34 PM Thread Starter
JPJ
Well I found a compromise, and was able to move the inner forward enough in the wheel well to get to the nuts without taking it out all the way.
Since it didn't matter if these bolts snapped I didn't go through a full penetrating oil routine. One broke on the first turn (I don't think it would have ever unthreaded with the way it was corroded), the other unscrewed without breaking. Will be soaking all the other locations for the next week or so. Hoping on the left side I can do the same with moving the inner out of the way, and don't snap any bolts or have problems with cage nuts.
JPJ is offline
post #7 of 8 (permalink) Old 01-22-2017, 12:05 PM Thread Starter
JPJ
Just as a follow up in case someone finds this post later. You can drop the inner fender or fully remove it with the outer in place. I removed the battery tray for the left side which was the most time consuming part of the job (getting to the front bolt). Looking at it now, I probably could skipped that step.
JPJ is offline
post #8 of 8 (permalink) Old 01-22-2017, 12:29 PM
1968gto421's Avatar
Quoted: 72 Post(s)
Thanks for posting this, it really helps!.. My brother is into Chevelles and he and his buddies have done it your way so I wondered if it couldn't be done with Pontiacs.
1968gto421 is online now
1969 GTO Fender Emblem placement Mainlin 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 5 03-18-2016 04:25 PM
1969 GTO Bucket Seat Removal/Install solsticegto 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 4 11-12-2015 06:17 PM
1969 GTO Front Fender Emblem Question saturnkk 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 0 10-29-2014 01:15 PM
1969 GTO Front Fender Supports moparmusclecars 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 1 09-30-2012 05:54 PM
