64 Tempest tail panel trim mounting holes - Pontiac GTO Forum
post #1 of 2 (permalink) Old 06-19-2019, 04:28 PM Thread Starter
Hi All,
If someone has the tail panel trim installed on a 64 Tempest, could you measure the mounting holes from the lip just above. My tempest never had this trim and there are not any holes. I would at least like to get somewhat close.
The curve in the panel makes it difficult to be exact. Maybe also the distance from the edge of the gas door to the first hole/stud too.
I am attaching a pic as a reference.
Thanks in advance for any help.
Sandy
ID:	119721   Click image for larger version
IBFraggin is offline
post #2 of 2 (permalink) Old 06-20-2019, 12:27 PM
Rlamarche1's Avatar
Quoted: 11 Post(s)
I have a 64 GTO. From the bottom of the lip inside the trunk to the center of the stud is 1 11/16 inches. The first hole from the edge of the gas door to the same stud is 2 1/12 inches. The thing is, I don't know if it is the same on a Tempest. Hope this helps.
Rlamarche1 is offline
