65 GTO Air Blower, Dash Cushion problems - Pontiac GTO Forum
post #1 of 4 (permalink) Old 08-09-2018, 05:55 AM Thread Starter
Hi everybody !
First of all i'm French, so sorry for my english.
I'm in the process of restoration of my Gto.
I presented it a few years back on the forum . I was in Mexico... now in France.
1/ First problem, first picture in order to understand.
https://www.gtoforum.com/attachment....114657&thumb=1
My problem ! I think the car was original equiped with A/C. Ex-"Mechanic" threw A/C it because it was heavy....
I just want to be able to have ventilation in the car .. In order to defrost etc...
I have a missing panel in the coil (passenger side ), i was thinking of fabricating a plate with a circular entry in order to connect the outlet of the blower ?
If someone has an idea im all ears open. Im in france and already spent more than 2500 euros in engine parts... So if it was a diy solution it would be great...
2 / Second problem
I cant take the pading of the dashboard out. Its cracked.....
I unscrew the three nuts 2 on passenger and one on driver side. Do i have to pull very hard or did i miss something ? Im struggling and didn t found any resource. I have a restoration book, but i feel its weak and missing a lot of info.
I feel its blocking in the area of clusters....
https://www.gtoforum.com/attachment....114659&thumb=1
Thanks in advance guys !
ID:	114657   Click image for larger version
el_papelitos is offline
post #2 of 4 (permalink) Old 08-11-2018, 04:26 AM
Joe'sToy's Avatar
Originally Posted by el_papelitos View Post
Hi everybody !
2 / Second problem
The dash pad has three screws that screw into the bottom of the dash pad and thread into the cluster housing right above the gauge cluster. You'll have to remove those and the pad will come out. Be careful, because now the housing holding the gauges is loose now and may fall forward.
Joe'sToy is offline
post #3 of 4 (permalink) Old 08-13-2018, 06:39 AM Thread Starter
Thanks Joe im going to try it !!!
post #4 of 4 (permalink) Old 10-16-2018, 03:33 PM
Quoted: 117 Post(s)
Yes, your car had factory AC. You can get a non-AC heater core/blower housing and go that way, or, what I would do (it is a 1965 GTO, and a classic) is get a Vintage Air air conditioning system and install it. It is a complete kit, and you will have brand new, working AC and heat. I was in France in '89 and saw ZERO Pontiacs, and one old Cadillac in Paris...that was it! Good luck. Remember, restoring this car/repairing this car won't be cheap, but every penny you spend will be worth it in the long run.
65 GP dash harness fit 65 GTO? pbertrand65GTO 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 0 04-18-2015 07:50 PM
1971 GTO Steering Wheel - C/S on Invoice or Custom Cushion in Brochures bucktazgto 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 0 07-26-2014 04:07 PM
65 GTO Heater Box Heater Core Blower Motor Questions WideTrack 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 02-06-2013 07:45 AM
friend of mine put blower on his 05' GTO! tiger gto Intake and Exhaust Discussions 5 08-14-2006 10:31 PM
