66 to 67 GTO fender differences - Pontiac GTO Forum
post #1 of 7 (permalink) Old 03-12-2018, 02:11 PM Thread Starter
Hi, I am trying to find out what is different between 66 and 67 GTO fender! I thought they were interchangable, but when I look at the aftermarket sites they have different part numbers for 66 and 67. I have a 66 GTO and a guy is selling 2 new in the box 67 fenders from Ames. I can't find any staight forward info on what is different. the Ames site says they will both need work around the headlight area?? I would rather find rust free origionals, but here in the northeast thats not going too well.. Any info is appreciated. Thank you, Dave
tonkatoy72 is offline
post #2 of 7 (permalink) Old 03-12-2018, 02:52 PM
64GTOConvertible's Avatar
Quoted: 17 Post(s)
64GTOConvertible is offline
post #3 of 7 (permalink) Old 03-12-2018, 04:37 PM
GTOJUNIOR's Avatar
Quoted: 65 Post(s)
What everyone doesn't seem to take note of is the forward/front header extension tab on the fenders.
The '66 Grill Header Panel was in basic terms an "I" while the '67 was a "T" the top portion of each Header Panel differ in size and contour.
If you have your old '66 Fenders you will need to carefully cut off the Header Extensions that are welded on the fenders and transplant them onto the '67.
Then it's just a matter of trim/emblem mounting holes.
Name:	66 GRILL-HEADER.jpg
ID:	106225   Click image for larger version
Name:	67 GRILL-HEADER.jpg
ID:	106233   Click image for larger version
Name:	66 vS 67 FENDER HEADRE TAB.jpg
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #4 of 7 (permalink) Old 03-13-2018, 09:29 AM
Quoted: 17 Post(s)
You could just change to the much better looking '67 nose...
post #5 of 7 (permalink) Old 03-13-2018, 03:35 PM
GTOJUNIOR's Avatar
Quoted: 65 Post(s)
Hey now...
post #6 of 7 (permalink) Old 03-13-2018, 07:50 PM Thread Starter
Thank you GTOJUNIOR and 64GTOConvertible for your replies. So if it is just that small piece at the header panel that is the only difference then it shouldn't be that bad to make the 67's fit. Personally I would like to have the 66 grille surround with the 67 mesh grilles!! Thanks again
post #7 of 7 (permalink) Old 03-14-2018, 04:26 AM
GTOJUNIOR's Avatar
Quoted: 65 Post(s)
Anyone with good cutting/welding skills could handle the extension replacement.
Here is the smaller '66 piece up-close, These need to be carefully removed from your old fenders.
04-06 GTO Differences GM4life 2004-2006 GTO General Discussion 21 11-04-2014 01:29 PM
'65 GTO Fender vs. '65 Tempest Fender DAbraham 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 10 11-21-2010 04:55 PM
66-67 GTO differences Oxen 1964-1974 Tempest, Lemans & GTO General Discussion 4 09-24-2010 06:14 PM
Differences between 05-06 GTO? saturnk1 2004-2006 GTO General Discussion 11 06-07-2006 07:56 AM
differences between 66/67 and 71/72 GTO freeyayo 1964-1974 Tempest, Lemans & GTO General Discussion 5 04-01-2005 11:40 AM
