66 GTO inside door panel removal - Pontiac GTO Forum
post #1 of 4 (permalink) Old 04-06-2015, 09:08 PM Thread Starter
I finally got a 66 remote mirror so now I need to remove the inside door panel to run the cable through the inside of the door. I do not want to damage the panel during the removal and the installation. The car originally had the remote mirror so the hole and a dummy toggle is already in place. Thanks
tonyli is offline
post #2 of 4 (permalink) Old 04-06-2015, 09:28 PM
Quoted: 106 Post(s)
Remove the armrest, remove window crank and door handle, remove screws at the bottom and lift from the bottom straight up and it should pop off...or down can't remember.
There are clips that it slides in along the sides so don't pull out or you may damage the back of the panel.
Goat Roper is offline
post #3 of 4 (permalink) Old 04-08-2015, 12:34 PM
Quoted: 118 Post(s)
Yes, self explanatory. Go slow, and use the special tool to remove the window crank and door handle 'c'clips. It's cheap and easy.
post #4 of 4 (permalink) Old 04-23-2015, 02:51 PM
Mikereps's Avatar
Quoted: 4 Post(s)
Related, the previous owner mounted the rear quarter window seals on the outside of the jam rather than inside. I need to move them an am assuming I need to remove the rear interior panels to do it. Your input on how to remove those panels would be very appreciated.
Mikereps is offline
65 GTO door panel removal waltcoleman 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 2 09-23-2012 09:10 PM
door panel removal MikeTheDiabetic Interior Discussions 3 04-19-2010 09:43 PM
Door Panel Removal Duffman6968 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 6 01-20-2009 09:53 PM
65 GTO door removal bluegoat2033 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 10 11-08-2008 10:42 AM
Door Panel Removal? LS2Monaro Interior Discussions 3 10-20-2008 11:59 PM
