67 GTO trunk help - Pontiac GTO Forum
post #1 of 3 (permalink) Old 01-07-2018, 08:00 PM Thread Starter
Quoted: 4 Post(s)
67 GTO trunk help
Hey guys, I have a car that needs pretty much every panel replaced that touches the trunk opening. Im looking for guidance as far as the order in which i replace them.
My current plan is to tack in a new tail panel to and then replace the trunk floor. Then work outwards with new inner and outer wheel wells and once I get the car back on the frame, I'll do the quarters. Is this the best way to do it?
Does anyone make the inside of the sail panel or will I have to fabricate one? Thanks and I welcome all advice and knowledge.
David18 is offline
post #2 of 3 (permalink) Old 01-11-2018, 08:34 AM
Cafr119's Avatar
Quoted: 38 Post(s)
Oh man, that sucks, Iím not sure if anyone does offer any sort of replacement for those areas, you might be in for the same road I will be headed on my 73 GTO, not much out there as for aftermarket sheet metal, I Love the 67/68 body style, sure hope one of members here can help you out.
Cafr119 is offline
post #3 of 3 (permalink) Old 01-21-2018, 05:29 PM
Cafr119's Avatar
Quoted: 38 Post(s)
You might want to get ahold of CTC Auto Farm in Texas or Franks Pontiacs a out in Calaforina and see if they have good sections cut out or maybe a better body for sale, otherwise locate a good metal fabrication shop that will fab up panels.
Cafr119 is offline
Trunk Floor Pan - can I use a 67 chevelle trunk pan in my 67 GTO SOCMedic 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 2 01-19-2015 09:30 PM
65 GTO trunk drop off help ElMedioGringo 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 2 09-18-2012 05:55 PM
69 GTO trunk pan DrBoeing 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 2 04-24-2011 06:58 PM
69 GTO trunk resto bigrc2 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 13 04-22-2011 06:28 PM
69 GTO trunk pan lanman68 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 2 10-02-2009 08:42 PM
