67 lower Door Trim Install - Pontiac GTO Forum
post #1 of 10 (permalink) Old 09-09-2015, 06:42 PM Thread Starter
Quoted: 4 Post(s)
Does anyone have instructions to install the GTO lower door trim on a 67? The Doors are for a tempest so there are NO holes and in the assembly manual it shows how to install the rocker trim, but nothing for the doors. (probably on one of the faded to nothing pages).
Also, when you install the GTO emblems on the rocker, did you need to grind down the emblem tabs so they don’t hit the car? Any tips welcome…
Thanks in advance.
Vapor Locker USA is offline
post #2 of 10 (permalink) Old 09-11-2015, 08:13 AM
'67 GTO lower door moldings accepted several clips, and original '67 GTO doors had at least 2 square holes die stamped into the outer door skin to accept the clips. Believe, I'm out of '67 doors in the door racks, or would get you some pics and measurements. I would pursue buying, or getting a scan out of a '67 Fisher body manual. Still, the best is the exact measurement off an original '67 GTO door.
post #3 of 10 (permalink) Old 09-11-2015, 12:30 PM
Quoted: 13 Post(s)
I have my 67 doors handy if you want pictures.
Let me know.
Colorado67GTO is online now
post #4 of 10 (permalink) Old 09-11-2015, 05:23 PM Thread Starter
Quoted: 4 Post(s)
That would be awesome. Tempest doors so no holes at all. I can see how the end clips will work but the center clips...... not so much.
[IMG]F:\1 PICTURES\67 tempest\door clip.jpg[/IMG]
post #5 of 10 (permalink) Old 09-12-2015, 12:42 PM
Quoted: 13 Post(s)
Try these pictures. If you need something different, let me know.
As for the clips, they twist into the molding and then the spring portion holds them into place. There should be a protruding stud with expanding fingers that go into the holes shown in my attached pictures. I think it is critical to get the up and own height correct and consistent. Side to side won't matter as much.
It will take a few posts to get all the pictures.
Name:	Passenger Door (1).JPG
ID:	64369   Click image for larger version
Name:	Passenger Door Rear to Front 1.JPG
ID:	64377   Click image for larger version
Name:	Passenger Door Rear to Front 2.JPG
ID:	64385   Click image for larger version
Name:	Passenger Door Rear to Front 3.JPG
ID:	64393   Click image for larger version
Name:	Passenger Door Rear to Front 4.JPG
post #6 of 10 (permalink) Old 09-12-2015, 12:45 PM
Quoted: 13 Post(s)
Continued
Name:	Passenger Door Rear to Front 5.JPG
ID:	64409   Click image for larger version
Name:	Passenger Door Rear to Front 6.JPG
ID:	64417   Click image for larger version
ID:	64425   Click image for larger version
Name:	Square Hole Size.JPG
post #7 of 10 (permalink) Old 09-12-2015, 12:49 PM
Quoted: 13 Post(s)
More Pictures
ID:	64481   Click image for larger version
Name:	Drivers Door Front to Rear 1.JPG
ID:	64489   Click image for larger version
Name:	Drivers Door Front to Rear 2.JPG
ID:	64497   Click image for larger version
Name:	Drivers Door Front to Rear 3.JPG
ID:	64505   Click image for larger version
Name:	Drivers Door Front to Rear 4.JPG
post #8 of 10 (permalink) Old 09-12-2015, 12:53 PM
Quoted: 13 Post(s)
Final set.
The pictures are named according to how they were measured. Make sure to note that the passenger door was measured rear to front and the drivers door is opposite.
Name:	Drivers Door Front to Rear 5.JPG
ID:	64529   Click image for larger version
Name:	Drivers Door Front to Rear 6.JPG
post #9 of 10 (permalink) Old 09-12-2015, 01:58 PM Thread Starter
Quoted: 4 Post(s)
That is awesome. It looks like once i have the 2 holes made on the end, the 1/2 inch holes are just in a straight line. I should have done this before paint.
Thanks for taking the time to take the great pictures and all of the measurements.
If your ever in the St Louis area, I owe you a beer..
Name:	door trim holes.jpg
post #10 of 10 (permalink) Old 09-12-2015, 04:11 PM
Great pics, Colorado67GTO!
Lower Quarter Panel Trim shelbee350 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 6 08-12-2012 12:10 PM
How do I remove the door vent trim & instrument cluster trim? batmans Interior Discussions 13 05-11-2011 07:11 PM
Rusted Out Lower Driver's Door Pillar Post JRStew 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 3 07-27-2010 11:36 AM
Need help 67 gto lower trim MI1967gto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 07-27-2010 11:26 AM
Trim along the lower back BlckGTO04 Exterior Discussions 1 04-09-2006 10:29 AM
