Correct Interior Color for 1968 Front Turn/Parking Light - Pontiac GTO Forum
post #1 of 1 (permalink) Old 02-17-2018, 12:34 PM Thread Starter
Quoted: 390 Post(s)
Thought I would add to the thread ""Correct interior finish for 69/70 GTO front parking light housing?" that was posted recently. It was decided that a reflective "metallic" finish was correct.
I just purchased a pair of used 1968 A-body front turn/parking light housings to replace the rotted ones on my '68 Lemans. They are stamped GUIDE 25, SAE DPP, 68. I was not able to find my originals to use as a comparison, but recall they were in pretty bad shape and I was not going to use them, so I most likely threw them out. Found the lenses only.
The interior finish on the '68 front turn/parking light housings are painted white. The metal housings are anodized and the white paint applied over this just in the front area that is concealed by the plastic lense. You can see in photo #2 that the white paint is behind the bulb socket/bracket, so it gets painted prior to the socket installation. So these would have not had the reflective metallic finish found on the 1969/70 units.
Just figured this info might be something for future use to someone restoring their 1968 front turn/parking signal light housings.
Name:	01  1968 GTO Front Signal Housing.JPG
ID:	103865   Click image for larger version
Name:	02  1968 GTO Front Signal.JPG
ID:	103873   Click image for larger version
Name:	03  GTO Front Signal.JPG
Correct finish for changing interior color turnjare 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 6 12-30-2018 01:31 PM
Correct interior finish for 69/70 GTO front parking light housing? Herding Goats 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 8 03-12-2018 08:31 PM
Turn Signal - Parking Light Question Bradysdad 1964-1974 Tempest, Lemans & GTO General Discussion 2 07-05-2017 09:22 PM
Correct 1968 engine block color MO Goat 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 3 09-17-2012 06:50 PM
Interior dash light color? cdcdude Interior Discussions 11 11-01-2006 07:21 PM
