Cowl Water Leak - GTO w/AC - Pontiac GTO Forum
post #1 of 1 (permalink) Old 03-11-2018, 03:25 PM Thread Starter
Roqetman's Avatar
Quoted: 16 Post(s)
Iím writing to see if anyone has a fix for a water leak coming in around the gasket where the AC/Heater box attaches to passenger side kick panel. My Ď65 GTO has factory air and the AC/heater box under the dash pulls in fresh air from cowl through the kick panel. When I pour water on the cowl in runs down inside the fender and most of it drains out the bottom of the fender but a small amount drains into the interior floor board. It appears to be coming in around the rubber gasket where the AC/heater box is attached to the inside metal kick panel. Has anyone else had this problem, if so what was the fix? Thank you!
Roqetman is offline
2004 GTO water leak Dudeman 2004-2006 GTO General Discussion 2 08-01-2014 10:19 PM
Water Leak SasdawgGTO Service, Maintenance and Technical Discussion 16 12-20-2013 01:57 AM
2004 GTO water leak Rock D. Interior Discussions 4 12-30-2010 02:46 PM
Water Leak in '06 Ladybug Interior Discussions 3 12-12-2008 02:17 PM
Water leak help!!! yellowracer 2004-2006 GTO General Discussion 6 05-11-2005 04:11 PM
