help finding part (fender brace) - Pontiac GTO Forum
post #1 of 13 (permalink) Old 12-19-2018, 02:39 AM Thread Starter
Stereolab42's Avatar
Quoted: 16 Post(s)
A small brace that holds the fender to the frame? I have one on the driver's side but am missing the one on the passenger's side. Can't figure out what it's called, have had no luck with Google.
Stereolab42 is offline
post #2 of 13 (permalink) Old 12-19-2018, 05:34 PM Thread Starter
Quoted: 16 Post(s)
I sent a pic to Ames and they said it's not OEM. But there are factory-looking screw holes that this fits into so clearly SOMETHING OEM goes there. Can anyone with a "more OEM" 68/69 GTO take a look and tell me what you see? I can always just get a bracket at Home Depot, cut it to length, and twist it in a vice to match, but I'd really like to know.
post #3 of 13 (permalink) Old 12-19-2018, 05:58 PM
Quoted: 391 Post(s)
Can't really tell from your photo - a good shot, but how about one a little further away to show placement and orientation.
My guess is that with all that undercoating, that is the lower fender brace area found at the back of the fender adjacent to the door? It should have a tab at the bottom of the fender where it gets bolted up to the lower cowl. That is not factory, so it looks like some one improvised to keep the lower fender from flopping in the wind.
post #4 of 13 (permalink) Old 12-19-2018, 07:29 PM Thread Starter
Quoted: 16 Post(s)
It's actually the the corner of the fender (if that's the right term) past the wheel, not before the wheel. Without it that piece is kind of floppy.
Name:	20181011_103604 - Copy.jpg
post #5 of 13 (permalink) Old 12-19-2018, 09:04 PM
Quoted: 391 Post(s)
OK, checked my book. Looks to be what is called the Valence Panel to Bumper Bar Support. Check this page out, it is Number 88 in the exploded diagram, page 88 and description is page 89. https://books.google.com/books?id=MG...upport&f=false
post #6 of 13 (permalink) Old 12-19-2018, 09:21 PM
FlambeauHO's Avatar
Quoted: 8 Post(s)
My 68 does not have that brace, there's a fender brace but it's shorter and stouter. I'll look for a pic.
FlambeauHO is offline
post #7 of 13 (permalink) Old 12-19-2018, 09:23 PM
FlambeauHO's Avatar
Quoted: 8 Post(s)
Just these fender to core support brackets, nothing to frame on mine.
post #8 of 13 (permalink) Old 12-19-2018, 11:15 PM Thread Starter
Quoted: 16 Post(s)
Thanks... guess I'll order that and see if it fits.
post #9 of 13 (permalink) Old 12-19-2018, 11:23 PM
FlambeauHO's Avatar
Quoted: 8 Post(s)
It goes in a different spot, I'll snap you a pic in a bit.
post #10 of 13 (permalink) Old 12-20-2018, 12:12 AM
FlambeauHO's Avatar
Quoted: 8 Post(s)
Now that I'm under the car I think I made this bracket during the resto, I believe I ordered the above brackets and they didn't fit in any rational manner. The one in your pic above is definitely home made as well. I'll attach a pic of mine and I'll do some research tomorrow as I'm doing work on the car again and may redo some of my previous work. Maybe someone else will chime in with the original setup... Cheers
Need help on finding this part Jstreet 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 28 12-21-2018 01:14 PM
Need help finding part quater window channel sky65 1964-1974 Tempest, Lemans & GTO General Discussion 0 04-02-2016 08:39 PM
need help finding part usnfenix 1964-1974 Tempest, Lemans & GTO General Discussion 1 11-12-2011 05:19 PM
Need help finding this part xconcepts 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 09-11-2011 07:33 AM
Need help finding a body part Fred007 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 4 08-30-2009 01:58 PM
