hood latch - Pontiac GTO Forum
post #1 of 4 (permalink) Old 01-30-2018, 07:02 PM Thread Starter
hood latch
I have a '68 GTO Vert and have always had problems with the ratcheting hood latch, I find that I really have to slam the hood to get it all the way down for body panels to line up properly, does anyone have experience replacing the ratcheting hood latch for a different style latch that will achieve the same outcome without slamming ?
thank you,
Tom
knauertone is offline
post #2 of 4 (permalink) Old 01-30-2018, 07:25 PM
integrity6987's Avatar
Quoted: 46 Post(s)
Are you happy with how the hood sits compared to the nose and fenders? One easy thing to try is adjusting the round rubber tops stops on the outside ends of the upper radiator support. if you lower these just a little it might latch much easier and not look bad.
DK
integrity6987 is offline
post #3 of 4 (permalink) Old 01-31-2018, 12:14 PM Thread Starter
Thank you for the suggestion but the bow that keeps tension on hood to lift it up when released keeps enough upward tension on the hood that you need to exert force to compress that enough for the ratcheting latch to start engaging but to make fenders and nose to line up perfectly you need to click it down once engaged 3 clicks. To achieve that you need to apply force when closing hood. I also have a '70 El Camino SS and that hood latch is entirely different and once caught it closes perfectly so I was looking for a latch that doesn't ratchet.
post #4 of 4 (permalink) Old 02-01-2018, 11:06 AM
1968gto421's Avatar
Quoted: 72 Post(s)
Have you checked to see if it's possible to install a latch set up like your El Camino has into the GTO. With some slight mods it may work. My '68 has a crappy hood latch too that gives alot of hassle to open the hood when the body panels are correctly aligned. I was thinking in desperation of hood pins but I hate to modify the hood. Another latch would be preferable.
Keep us posted, Thanks.
1968gto421 is online now
68 convertible hood latch alignment Oldphart 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 3 02-26-2016 04:31 PM
1969 GTO hood latch DSW 1964-1974 Tempest, Lemans & GTO General Discussion 1 03-20-2013 09:46 PM
hood latch spring Topkat 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 1 11-18-2010 09:25 PM
Hood Latch on a 65 injn37 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 24 04-22-2010 10:01 AM
Hood Latch Fell Off! Goatman455 1964-1974 Tempest, Lemans & GTO General Discussion 14 06-12-2009 10:02 AM
