How To Remove Door trim from GTO?? - Pontiac GTO Forum
post #1 of 4 (permalink) Old 06-07-2015, 10:26 AM Thread Starter
Is there a way to remove the door trim without damaging it to be reused?? Or if I remove it, I can't use it again. Any help is appreciated. Thanks.
Mr66GTO is offline
post #2 of 4 (permalink) Old 06-07-2015, 02:01 PM
Been a while since have pulled the '66-67 anodized alum trim. Have pulled quite a few pieces over the years, and have several pieces that are undented. Clearing the cobwebs a little... to remove the trim, first have to pull the door and vent window handles, then unscrew the arm rest, remote mirror bezel (if equipped), then remove the doorpanel. Next you find the window stop that prevents the window from going too low. After you have the window lower than at normal low spot, you can get to the small, believe small black Phillips head screws that hold the anodized trim to the top of the door, hope this helps.
post #3 of 4 (permalink) Old 06-07-2015, 06:38 PM Thread Starter
This is the trim I am trying to remove without damaging it. Is it possible or will they get damaged??
Mr66GTO is offline
post #4 of 4 (permalink) Old 06-07-2015, 09:22 PM
Aaah, 2 door post trim!
Clearing the cobwebs...there are 3 or 4 screws that hold the curved piece of trim above the rear 1/4 window. the piece in front of it, the vertical sash is held on with 3 or 4 clips. The door pieces have to carefully bump them off, will get re aquainted with a post door tomorrow, usually I just sell clean two door post doors with the anodized trim and don't mess with removing it.
67 gto stainless trim along sill how to remove fiesta62 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 04-22-2014 08:18 PM
How to remove trim around convertible? facn8me 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 2 04-13-2012 07:03 PM
64 Post Trim - how to remove jvongray 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 2 10-14-2011 09:28 PM
How do I remove the door vent trim & instrument cluster trim? batmans Interior Discussions 13 05-11-2011 06:11 PM
How To Remove GTO Steering Wheel Trim Covers???? 1LS1 2004-2006 GTO General Discussion 1 01-05-2011 11:21 PM
