Power steering gear box - Pontiac GTO Forum
 1Likes
  • 1 Post By GTOJUNIOR
post #1 of 6 (permalink) Old 01-14-2019, 07:24 PM Thread Starter
gtoearl's Avatar
Quoted: 22 Post(s)
I have a 1966 Pontiac GTO. I am going to replace the power steering gearbox. I need some advice from you guys on which ratio to purchase. Should I buy that 2 1/2 to 3 1/2 turns or replace it with what is currently I believe stock in the car, 3 1/2 to 4 1/2 turns. Thanks for any feedback
gtoearl is offline
post #2 of 6 (permalink) Old 01-15-2019, 05:22 AM
deanhickey's Avatar
Quoted: 38 Post(s)
I would seriously think of having it rebuilt, it can be done with modern internals and maintain original appearance. There are small companies that can do this for around 400.00. Talk to Marty at Powersteering.com and he can answer your questions.
deanhickey is offline
post #3 of 6 (permalink) Old 01-15-2019, 05:34 AM
GTOJUNIOR's Avatar
Quoted: 65 Post(s)
If your maintaining a very correct car then rebuilding the OE box is recommended.
Wanting to limit down time I went with the Jeep GC gear box.
I went this route for way under 400$ and I'm very pleased with the results and
may have the OE box rebuilt sometime down the road but for now I'll stay with the jeep box.
The JGC box is very very close to stock appearance and is a direct bolt-in.
Check the web there are many many topics on this.
deanhickey likes this.
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #4 of 6 (permalink) Old 01-15-2019, 11:23 AM Thread Starter
gtoearl's Avatar
Quoted: 22 Post(s)
Thanks For all the responses. Napa has a direct fit replacement rebuild steering gearbox for $130. My brother just bought one for his 68 El Camino and ironically it’s the same part number for the 66 Pontiac. I will compare his out of the box with what I have on my car to see if it is similar appearance . I would assume these rebuilt ones are from original OEM boxes. My question again to all of you is what ratio do you think I should do. In other words which one do you guys like. The quick ratio or the standard OEM ratio.?
gtoearl is offline
post #5 of 6 (permalink) Old 01-15-2019, 06:12 PM
GTOJUNIOR's Avatar
Quoted: 65 Post(s)
The JGC box is a quick ratio box. If I ever do have my OE re-built it too will become a QR box.
post #6 of 6 (permalink) Old 01-17-2019, 10:18 AM
DT-Fan's Avatar
Quoted: 5 Post(s)
I will need to do the same on my '68 GTO - Gearbox spits Oil heavily. A rebuild will be around 600/720$, but I found this replacement , which looks reasonable to me.
Anyone objections?
1968 GTO Convertible
1978 Yamaha DT 400 MX
2018 Grand Cherokee SRT
DT-Fan is offline
Power Steering Gear Box kilkm68 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 6 10-15-2014 07:20 PM
Steering Gear Box Mounting Holes Josh.AZ.GTO 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 1 08-06-2014 06:04 AM
Steering gear Box Numbers shelbee350 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 1 03-04-2012 10:37 PM
Steering gear box color Chris Holabaugh 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 13 07-30-2010 05:41 AM
