Quality of aftermarket quarter panels - Pontiac GTO Forum
post #1 of 8 (permalink) Old 07-15-2017, 01:01 PM Thread Starter
Quoted: 9 Post(s)
Hello All,
I'm going to need to replace the rear quarters on my 1969 tempest convertible. There appear to be several aftermarket companies that make them. Any advice on which company may be the best or which one to avoid.
Thanks for your help,
Armand
ajluzi1957 is online now
post #2 of 8 (permalink) Old 07-16-2017, 10:04 PM
Quoted: 79 Post(s)
Originally Posted by ajluzi1957 View Post
Hello All,
Armand
Are you talking about skins? Full quarters are not reproduced for convertibles so you are going to have to find a donor car or splice the reproduction quarters onto your original panels. If the upper section is good on your car then you are in luck. I used a full quarter from Dynacorn and spliced it to the upper section from a donor car. The Dynacorn full quarter fit very nice....probably the best fitting repop panel that I've ever worked with. The radius edge around the door jamb was good....but not as tight as the original panel so I kept the OE edge. It was a lot of extra work but I didn't want to give up that factory look at the door gap. The door gap on the Dynacorn panel was nice and followed the door correctly so it could be used as is and 98% of the people would never say a word about it. The first photo is the Dynacorn panel. The second photo is the OE gap. You can see the Dynacorn gap is pretty close to factory....not perfect but pretty darn close. The remaining pics are from our qtr repair process.
Name:	01 Dynacorn gap.jpg
ID:	94017   Click image for larger version
Name:	02 OE Gap.jpg
ID:	94025   Click image for larger version
Name:	03 qtr kleeko.jpg
ID:	94033   Click image for larger version
Name:	04 butt weld.jpg
Shake-N-Bake is offline
post #3 of 8 (permalink) Old 07-17-2017, 08:44 AM Thread Starter
Quoted: 9 Post(s)
Thanks for your response.
Most of the metal appears to be good at the top, I have some rot and rust around the wheel wells. The body shop that I went to told me it would be much less labor to get the panels and have him install than for him to fabricate metal and fix the wheel wells. Also said it would be less expensive than patch panesl.
Not sure whether to go with skins or the full quarter and have him cut it down.
post #4 of 8 (permalink) Old 07-17-2017, 10:48 AM
Quoted: 79 Post(s)
If the door jamb is still good on your car then it sounds like the skins will work for your needs. The full quarters have the door jamb, reveal edge around the qtr window, the top surface to the deck lid and the rear corner.....all stuff that gets cut off for a convertible because the hardtop is different in all those areas.
Your body guy has a reasonable plan. I would try the skins vs trying to fabricate by hand. The skins might not be perfect but a good body guy can massage the panels to fit pretty nice.
Sent from my XT1585 using Tapatalk
post #5 of 8 (permalink) Old 07-17-2017, 01:13 PM Thread Starter
Quoted: 9 Post(s)
Thanks for the help! Goodmark has skins available. Do you think they are reasonable quality?
post #6 of 8 (permalink) Old 07-17-2017, 10:09 PM
Quoted: 79 Post(s)
Not sure. Never used skins on these cars. In my experience it's very hit and miss for what fits well and what doesn't. I think all vendors have some great fitting parts and some that don't quite measure up. If you are going to let someone else repair the quarter then you might want to let him source the replacement panels. That way if it doesn't fit well he will deal with it. I usually don't buy replacement panels until AFTER the body is blasted/stripped/etc. It's not uncommon to discover more damage or rust than you originally planned for. All the sins will be revealed once the car is stripped down to bare metal.
post #7 of 8 (permalink) Old 07-18-2017, 08:44 PM
Quoted: 31 Post(s)
[QUOTE=Shake-N-Bake;805601]
Not sure. Never used skins on these cars. In my experience it's very hit and miss for what fits well and what doesn't. I think all vendors have some great fitting parts and some that don't quite measure up. If you are going to let someone else repair the quarter then you might want to let him source the replacement panels. That way if it doesn't fit well he will deal with it. I usually don't buy replacement panels until AFTER the body is blasted/stripped/etc. It's not uncommon to discover more damage or rust than you originally planned for. All the sins will be revealed once the car is stripped down to bare metal.[/QUOTE
Hope this is not high jacking thread but could some one take pictures and outline where the difference starts? I don't know if I can get away with patches or skins or full quaters for my 68 convertible . Thanks Doug
dd68gto is offline
post #8 of 8 (permalink) Old 07-19-2017, 12:53 PM
Quoted: 79 Post(s)
The shaded area is different between convertibles and hardtop cars for 68. (Not sure about 1969 models but I would suspect a similar story..)
As an additional note... The decklid is the same for convertible or hardtops but the hinge pockets are different as are the torsion rods.
New 67 GTO quarter panels 01freeman 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 6 02-15-2018 05:15 PM
67 GTO Quarter panels brad900 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 0 07-23-2016 02:11 PM
Quarter Panels orelog 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 2 01-29-2012 10:59 AM
Quarter Panels - 64 on 65 OK? DAbraham 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 5 07-06-2010 06:02 AM
Quarter Panels Fred007 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 8 08-23-2009 08:01 AM
