Re installing Fender and inner wheelwell 1969 GTO - Pontiac GTO Forum
post #1 of 5 (permalink) Old 08-30-2018, 10:56 AM Thread Starter
Hi,
I removed both the drivers fender and inner wheel well during a disc brake conversion and complete front end rebuild. It is now time to re install. I took it apart as two parts, but I am wondering if I can install the inner wheel well to the fender and then install it as one piece? If the answer is no I assume the inner fender well must go in first loose and then install the fender? BTW I have not removed the front nose, do I need to loosen it up to do this? Any advice would be great for those that have done this before.
Scott Youngman is offline
post #2 of 5 (permalink) Old 08-30-2018, 02:34 PM
Quoted: 79 Post(s)
I believe the factory installed the fenders with the inner fender attached so it should be possible. I haven't tried it yet though....will find out soon myself.
Shake-N-Bake is offline
post #3 of 5 (permalink) Old 08-31-2018, 12:33 PM Thread Starter
Well if you get to it before me tell me how you make out and I will do the same.
post #4 of 5 (permalink) Old 08-31-2018, 01:31 PM
69matadored's Avatar
Quoted: 5 Post(s)
you can install the inner after the outer is on ,it takes a bit of twisting and manipulating but it can be done. My inner had been powder coated before installed and it picked up some scratches during this process
69matadored is offline
post #5 of 5 (permalink) Old 08-31-2018, 03:16 PM Thread Starter
Yea I was hoping to install the inner to the outer fender first and put it on as one piece....just not sure you can do that.
1969 GTO inner fender removal JPJ 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 7 01-22-2017 12:29 PM
wheelwell alignment question Reb 1964-1974 Tempest, Lemans & GTO General Discussion 1 01-29-2014 02:40 PM
Question on '65 fender clips (inner and outer) Fred007 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 4 08-07-2011 01:49 PM
Installing inner fender seals on a 68 GTO dglty 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 3 04-07-2010 07:49 PM
