Repair methods for a hood dimple - Pontiac GTO Forum
post #1 of 3 (permalink) Old 02-27-2017, 07:38 AM Thread Starter
Hey guys, I've run into a dent that is being extremely difficult to pull out. How would you recommend to fix something like this? I can't seem to be able to pull it out with my stud welder and slide hammer. I had someone mention a fiberglass filler, but I'm afraid of doing that to something that gets pressure against it. I'm thinking about actually cutting the corner out so I can hammer it out and then weld it back into place.
Any ideas?
The second image is how it's supposed to look. (opposite side)
Name:	20170224_112319 (Small).jpg
ID:	87946   Click image for larger version
Name:	20170224_112328 (Small).jpg
1964SS is offline
post #2 of 3 (permalink) Old 02-27-2017, 10:12 AM
Since its in the inner structure, & the die stamping of the recess has created stiffening, agree, proceed with cutting it out to repair. Scribe 4 lines & with a very careful hand with Dremel cut off wheels. Prob going to have some "fun" once the piece is out & you're working it on the bench. might consider taking a piece of oak & cutting out several blocks with a hole saw. Use one at a time as a backer board as you beat on the backside. A piece of steel plate would even be better, ESP if you can cut a same diam hole in it, with slight radius on the edge.
post #3 of 3 (permalink) Old 02-27-2017, 03:59 PM Thread Starter
Thanks Pinion! That's pretty much what I felt needed to be done as well.
1964SS is offline
Hood repair johnfin 2004-2006 GTO General Discussion 3 09-06-2014 08:14 AM
