shaved door handles - Pontiac GTO Forum
post #1 of 2 (permalink) Old 06-18-2019, 10:51 PM Thread Starter
shaved door handles
has any body put a shaved door kit in an a body cant find a spot to install solenoid that does not interfere with window I put it in the front lower corner but it wont pull far enough to open door any ideas would be appreciated wished I did not do it but paint is done at do not want to try to go back to regular door handles and repaint
thanks
goat70 is offline
post #2 of 2 (permalink) Old 06-20-2019, 09:42 PM
Quoted: 404 Post(s)
thanks
Don't know what "won't pull far enough" means? Rod not long enough or the solenoid does not have enough movement to pull the door lock?
I have never installed one. But if the movement is not enough, the closer you move the attachment rod/hole to any pivot point, the more movement you will get. Maybe move the rod attachment hole in on either the unlocking arm on the door lock or solenoid?
I would send a Personal Message (PM) through the website and contact our "custom" car builder. No doubt he will have the answer for you and get you on track. https://www.gtoforum.com/f83/gto-vette-hybrid-133465/
PontiacJim is online now
