Wheel house differences 68-69 HT/conv. - Pontiac GTO Forum
post #1 of 4 (permalink) Old 03-08-2019, 10:51 AM Thread Starter
Anderslober's Avatar
Quoted: 23 Post(s)
Hello. I may need new rear outer wheel houses for my 1968 GTO conv.
I can find plenty wheel houses on the web.......but will these work for a convertible? Or are there differences? Thanks...
Anderslober is offline
post #2 of 4 (permalink) Old 03-08-2019, 05:54 PM
Quoted: 79 Post(s)
They appear to be different. Unless yours are in very bad condition, it might be better to repair what you have vs trying to find full replacements.
Shake-N-Bake is offline
post #3 of 4 (permalink) Old 04-17-2019, 08:03 AM
Joust's Avatar
NO, they won't without a lot of modification.
I am doing my 69 convertible now and bought new wheelhouses.
there are some threads of guys modifying these but in reality it appears tough. my old parts were bad and were cut out and thrown away so i have no template.
i do see the 1970-1972 Chevelle Convertible Outer Wheelhouse available out there. I'm wondering if it may be easier to adapt these than the 68/69 coupe versions.?
Thoughts?
Joust is offline
post #4 of 4 (permalink) Old 04-19-2019, 11:09 PM
Convertible Wheelhouse
I am restoring a 68 GTO convertible. After searching grave yards and after market extensively, I can say no one makes an aftermarket convertible wheelhouse but the hard top is similar. I found one in a grave yard but the guy wanted to rape me. (he knew what he had) I had to modify the hardtop wheelhouse to fit the convertible. The biggest difference is the top of the wheelhouse was flattened to accommodate the convertible top when folded into the body. I was fortunate to have one partially rusted original inner and outer wheelhouse and had to make a mirror image to fit the opposite side which was trashed before I bought the car. It took me many months and lots of trial and error fits to get it correct. Then I restored the rusted out sections of the original wheel house. Learned a lot about working with sheet metal and welding which was good experience when I got to the body and floor damage.
If you don't have a model wheelhouse to work with, I cant imagine how you can possibly fabricate one that will fit. I would find someone with a convertible that will let you spend a day making measurements and templates.
BIgsteve188 is offline
Verdoro Green Differences between 67/68 - 69/70 with Pictures Corellian Corvette 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 1 04-22-2013 12:30 PM
69 GTO Outer Wheel House Fit Issues FooGee 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 8 12-20-2012 04:47 PM
68 GTO Convertible Outer wheel house rear. mohrfeld16 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 02-18-2010 07:34 PM
