14x6 rally 2 wheels - Pontiac GTO Forum
post #1 of 2 (permalink) Old 07-13-2012, 03:33 PM Thread Starter
14x6 rally 2 wheels
i have a set of four wheels all numbers match. they are stamped 14x6 JJ and on valve stem m53 6 17kx i would like to learn anything i can about them. the other #s on the inside are 6 6 83 ym thanks.
stevebrochu is offline
post #2 of 2 (permalink) Old 07-20-2012, 12:03 AM
The KX wheel was originally found on the Grand Am. Your wheel decodes are follows; M5=manufacture plant, 3=1983, 6=June, 17=17th day, KX=code. The JJ on the inside merely means it is a Rally II style. The 6 6 83= June 6, 1983 which is the date code on the inside section of the two piece wheel. The June 17 date on the outside is the final assembly date of the wheel. These are 14x6 wheels with 4.75x5 bolt circle and will work on disc brake applications.
John
GTO JOHN is offline
14x6 rally wheels what best tyre size looking for redlines fiesta62 1964-1974 Tempest, Lemans & GTO Wheels & Tires 10 10-25-2011 12:44 AM
14x6 Rally II Tire Size sixeightGTO 1964-1974 Tempest, Lemans & GTO Wheels & Tires 2 10-22-2010 12:43 PM
rally 4 wheels...value? xcmac26 1964-1974 Tempest, Lemans & GTO Wheels & Tires 9 03-12-2010 11:04 PM
Best tire size for 14x6 Rally II's? docmark1 1964-1974 Tempest, Lemans & GTO Wheels & Tires 1 05-19-2009 06:22 PM
