1967 wheel/tire size - Pontiac GTO Forum
post #1 of 16 (permalink) Old 11-13-2013, 12:32 PM Thread Starter
nitrous67gto's Avatar
Hey everyone,
I have a set of american racing 15 x 8" wheels on my 67 gto, the tire size I currently have on the rims is 215x 75 x 15, In the rear of the car I have a problem with the tires rubbing the wheel wells and has actually scratched up the tires when I hit bumps or go through dips, I would actually like to get some new tires that are bf goodrich radial t/a's 235 60 15, but I think these will rub as well, does anyone have some advise on weather the new tires will fit and also if there is some modification I can do to the car to make them fit, I don't mind raising the rear of the car a little if that is how I can make the tires fit.
nitrous67gto is offline
post #2 of 16 (permalink) Old 11-13-2013, 12:43 PM
I had to trim the inside edge of the wheel well and install drag bags (not to raise but keep it from squatting too far under WOT) to keep my tires from rubbing. 295/50/15's
post #3 of 16 (permalink) Old 11-13-2013, 03:19 PM
chuckha62's Avatar
Quoted: 18 Post(s)
I'm running 235-60's on a 7 inch wheel and the tires are nowhere near rubbing on anything. If you're rubbing with 215's I'd be more concerned about the offset on your 8 inch wheels.
chuckha62 is offline
post #4 of 16 (permalink) Old 11-13-2013, 03:41 PM Thread Starter
wheel/tire
I agree, I think that I may just have the wrong back spacing for the car. Do you have air shocks or bags or any kind of special suspension in the back to raise the car up so it won't rub? or do the 235's fit inside the rear wheel wells?
thanks
post #5 of 16 (permalink) Old 11-13-2013, 07:01 PM
Ideally you don't want the tires to rub at all anywhere in the suspension travel. Invariably you will bottom out or fully extend the suspension on your car and tires rubbing can actually upset the handling of the car. If you run air shocks to keep the tires from rubbing if you blow a shock you will come down on the tire. You really need the correct offset wheel to correct this. I recommend centering the wheel/tire in the wheelwell with at least 1/2" clearance if not more at all times.
post #6 of 16 (permalink) Old 11-13-2013, 09:20 PM Thread Starter
wheel/tires
That makes sense, does anyone know what backspace on a 15" x 8" rim will fit and give that clearance, maybe a 15 x 7 with the right backspace would be a better option, I would like to use 235 x 60 15" tires all the way around if possible.
Thanks again for the advise
post #7 of 16 (permalink) Old 11-14-2013, 08:35 AM
SANDU002's Avatar
I have 235x60x15 all the way around with no problem. Backspace is 5".
67 Post Coupe,
69 RA III Judge
06 BOM, M6, 18's
SANDU002 is offline
post #8 of 16 (permalink) Old 11-14-2013, 08:41 AM
chuckha62's Avatar
Quoted: 18 Post(s)
I'm running 15x7 Ralley II's with whatever backspacing came from GM. In the rears I have absolutely no issues whatsoever with factory springs and KYB GR-2 shocks. In the front I have a weak spring on the driver's side and once in awhile while I have a passenger in the car with me, I'll get a rub on that side when turning right and braking at the same time. I need to replace the front springs and shocks, when I get a chance.
post #9 of 16 (permalink) Old 11-14-2013, 08:56 AM Thread Starter
wheel/tire
Alkygto, makes a good point, that exactly what happened to me, I had 2 people in the back seat and the air line to the air shock came into contact with the exhaust just slightly, melted a hole in the line and the car just fell down and the lip on the wheelwell shreaded the sidewalls of the back tires. Sounds to me like I need to find some new wheels 15 x 7 with a 5" backspace to accomodate the 235 60 15's all the way around the car to avoid the rubbing issues. While we are on the subject, I do have air shocks on the rear of the car and the car seems to sit level when the shocks are completely full of air which makes for a pretty rough ride. Do you guys think the shocks I have are too short?
thanks
post #10 of 16 (permalink) Old 11-14-2013, 04:27 PM
crustysack's Avatar
I agree back spacing is off, find correct bs and you can run those tire sizes no problem (even wider in back) then tune the ride height with correct spring size (+2,+1,stock,-1,-2)
and then ditch the air shocks, pumping them up is for increased load not ride height adjustment, when you jack them way up with no increased weight in the car the ride will be super stiff( as you have found out) and NOT handle better, a new pair of gas shocks will make a world of difference (with proper springs)
crustysack is offline
Wheel/tire size options SWGOAT Wheels and tires 0 11-08-2011 10:53 PM
Wheel and Tire size for 65 GTO ningals3223 1964-1974 Tempest, Lemans & GTO Wheels & Tires 0 09-25-2011 12:16 PM
wheel and tire size limits charlie4170 1964-1974 Tempest, Lemans & GTO Wheels & Tires 11 05-20-2011 11:17 AM
1967 tire size tprusak 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 04-12-2010 02:25 PM
Front tire size for 1967 GTO ppurfield001 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 11-17-2008 06:42 PM
