1968 GTO Wheel Swap - Pontiac GTO Forum
post #1 of 3 (permalink) Old 12-12-2013, 02:31 PM Thread Starter
1968 GTO Wheel Swap
trying to swap out my stock 15" wheels for 18" wheels.
what is the maximum wheel width dimension possible on the rear end without requiring modification to wheel wells?
note: i'm running a stock 1968 pontiac 10 bolt rear axle.
thanks for your help.
1968 GTO Resto-Mod is offline
post #2 of 3 (permalink) Old 12-12-2013, 07:14 PM
I run a 9 1/2 inch wide wheel with a 12.5 x29 MT ET Street. It is the max tire I could fit in there.
I'm sure with a resto mod you are wanting a 17" or larger wheel and tire. I would recommend a Percy's Wheel Rite to figure out the max wheel and tire setup you can run.
post #3 of 3 (permalink) Old 12-13-2013, 06:05 PM
Get yourself a Percy's Wheel Rite tool (google it). And use it to measure. That's the best way. There's more to it than just width. You've got to get the correct back-spacing too.
1968 GTO Wheel Swap 1968 GTO Resto-Mod 1964-1974 Tempest, Lemans & GTO Wheels & Tires 0 12-12-2013 01:53 PM
Removing a 1968 GTO steering wheel MO Goat 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 13 12-31-2012 01:36 PM
1968 Engine swap GTOFreak68 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 7 03-23-2010 09:47 AM
