1968 GTO wheels - Pontiac GTO Forum
post #1 of 6 (permalink) Old 10-16-2011, 08:20 AM Thread Starter
1968 GTO wheels
Did all 68's come with 14" rims only or were 15's an option . I was going to go with the 17" torque thrust II 's and still might but Im also considering other options such as 14x7 or 15x7 rallye wheels .With either of the rallye 7" wide wheels whats the possibility of running into rubbing issues?
68gtohawk8369 is offline
post #2 of 6 (permalink) Old 10-16-2011, 08:56 AM
The '68's with disc brakes had a different back spacing to clear the calipers. In '68 you could get the Ralley I, Ralley II, or plain steel with hub caps all were 14" wheels. The 15x7" wheels will not interfere with disc brakes, and you should not have a problem with rubbing.
68raGTOp is offline
post #3 of 6 (permalink) Old 10-16-2011, 02:13 PM
Quoted: 98 Post(s)
15's were not an option in '68. Only 14's. I've been running a set of 14x7 Rally II's on my '67 GTO since '88, and I love the looks. 225/70/14 tires, no rub. I think 15 inch wheels look good on these cars, though, and if you want to run 15 inch Rally's, tires are easier to get these days.
post #4 of 6 (permalink) Old 10-16-2011, 06:04 PM Thread Starter
1968 gto
sounds like what im after is a set of 14x7's . Thats a shame I found a set of 15x7's with good rubber , priced right in good shape not to far from me .
post #5 of 6 (permalink) Old 11-25-2011, 05:53 PM Thread Starter
68 gto wheels
I found another set 14x6 my car has drums all the way around if these wheels are from a disk brake car (front) will they work ?
post #6 of 6 (permalink) Old 11-25-2011, 08:28 PM
FlambeauHO's Avatar
Quoted: 8 Post(s)
My 68 has 15x7's and I read that they were an option for rally II's but not the rally I's I've also heard the 14" rims have trouble clearing disk brake components...
FlambeauHO is offline
HELP with wheels and tires.. 18x9.5" wheels?? GTOFEVR Wheels and tires 1 04-08-2010 04:12 PM
looking at 1968 gto huggytree 1964-1974 Tempest, Lemans & GTO General Discussion 4 09-11-2009 04:50 AM
1968 Ram Air Carb Pan ..... ramairthree 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 04-04-2009 05:52 PM
