1969 GTO tire size for 17" wheel - Pontiac GTO Forum
post #1 of 6 (permalink) Old 08-11-2018, 12:41 PM Thread Starter
Want to replace wheels/tires with 17". Recommended what maximum size front and rear tires and backspacing for wheels? Would like to maintain same tire height, rolling distance as original. All comments appreciated. Thanks
CushmanEagle is offline
post #2 of 6 (permalink) Old 08-11-2018, 01:26 PM
Quoted: 399 Post(s)
Try doing a search using the Search engine in the upper right hand corner. Many wheel tire combos have been posted and you may find what you are looking for.
post #3 of 6 (permalink) Old 08-11-2018, 11:11 PM Thread Starter
17" tires and wheels for 69 GTO
I wasn't able to find the answer to my question, that is why I asked for help!
post #4 of 6 (permalink) Old 08-12-2018, 01:09 AM
Quoted: 161 Post(s)
https://www.pro-touring.com/archive/...p/t-47604.html
Looks like : 17x9.5-inch with 5-1/2-inch backspacing front, 17x11 with 5-1/2-inch backspacing rear. Use 275/40 front tires and 315/35 rear. This is tight in the rear. Of course every car is a little different, and brakes change things, so measure carefully!
That is some serious rubber!!!
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is online now
post #5 of 6 (permalink) Old 08-12-2018, 08:51 AM
Quoted: 399 Post(s)
Pulled this one out of the Search engine pretty quickly! https://www.gtoforum.com/f138/69-gto...choices-88129/
1968 GTO will also be the same so there may be other posts!
post #6 of 6 (permalink) Old 08-12-2018, 08:55 AM
Be very careful. These things are working against you - factory "tolerances" during assembly, possible previous disassembly and/or collision damage, changes by a previous owner that you may be unaware of, sagging springs, etc. can all cause differences from one car to the next even of the same make, model, and year. What fits on my 69 may not fit on yours and vice versa.
The only way to know what will fit on your car is to measure your car.
This tool helps a lot. I bought one myself.
https://www.summitracing.com/parts/php-01201
Wheel size and tire size Jarzone Wheels and tires 2 03-04-2016 02:19 PM
67 gto lemans 17" rim tire size help bbetz999 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 01-14-2015 07:49 PM
widest tire size for stock 04 17" wheels stephen77375 Wheels and tires 1 11-13-2011 10:15 PM
Tire options for stock 17" size? Poncho Dan Wheels and tires 2 07-01-2009 08:49 AM
Stock 17" rim tire size question zomowiec Wheels and tires 0 02-23-2008 11:17 AM
