5x120mm will these wheels fit - Pontiac GTO Forum
post #1 of 14 (permalink) Old 12-18-2012, 08:10 AM Thread Starter
bobby326's Avatar
I want to buy a pair of wheels but the bolt pattern is 5x120mm. On the web site which is discount tire they are pictured on a new camaro. Will this bolt pattern fit me 67 lemans 5x4.75/5x120.65. Will the .65 make enough of a difference that it cause a problem any help would be appreciated. Pulling me hair out trying to find a set of wheels to fit my car. I need a 6 inch or more of backs pacing to fit a 275. The wheels I'm looking at are bravado Americanas
bobby326 is offline
post #2 of 14 (permalink) Old 12-18-2012, 08:41 AM
I know that you can mount them.. but if its a good idea to use the wrong bolt pattern.. can't tell! BMW has 120mm and I had one on my GTO to test something.. didn't drive it.
If you use special nuts it will work just fine.. something like this: http://www.x-parts.de/pics/1039021_2.jpg These nuts "correct" up to 2mm difference in bolt patterns and the difference is less than 1mm. (don't know the englisch word for this kind of nut, sorry)
Chris-Austria is offline
post #3 of 14 (permalink) Old 12-18-2012, 08:50 AM Thread Starter
bobby326's Avatar
Thank you didn't know they made special lug nut for this set up
bobby326 is offline
post #4 of 14 (permalink) Old 12-18-2012, 08:59 AM
HP11's Avatar
Quoted: 24 Post(s)
Yeah, that really is 'special'. I've seen those on so-called 'rice' cars. Does that concept even seem right to you? A lug nut that 'floats' to take up the slop of installing a wheel with the wrong bolt pattern? If so, put them on your car; it's your car. JMO......
HP11 is offline
post #5 of 14 (permalink) Old 12-18-2012, 09:08 AM
jmt455's Avatar
You can probably get a 120mm bolt circle over the studs, but I wouldn't recommend driving it that way. I would find wheels with the correct bolt circle (4.75" or 120.65mm).
Check out this thread: Official Tire and Wheel Combo Thread, Post your combo here! - PY Online Forums
Posts 84, 87 and 110 might be of interest.
1968 Pontiac GTO
2008 Pontiac G8 base
jmt455 is offline
post #6 of 14 (permalink) Old 12-18-2012, 09:24 AM Thread Starter
bobby326's Avatar
I can't find these lug nuts. Does any body know we're I can order these or recommend using them
bobby326 is offline
post #7 of 14 (permalink) Old 12-18-2012, 09:49 AM
jmt455's Avatar
I would get wheels with the correct bolt circle.
1968 Pontiac GTO
jmt455 is offline
post #8 of 14 (permalink) Old 12-18-2012, 10:28 AM
It's always best to use the correct bolt pattern. I can find a source of such nuts if you want to import them.. They can safely be used in my opinion. This is what they are made for and the difference is only 0.65mm on your car.
Edit:
They call them floating nuts and would ship to the United States, but I'm sure you can get them cheaper somewhere in the US:
http://spurverbreiterung.de/product_...&info=p9529_KE 60°+Versatz***L: 0 (=Mutter)***SW 19.html&cat=c354_nach-Gewinde.html&bezeichnung=&typ=
post #9 of 14 (permalink) Old 12-19-2012, 10:21 AM
HP11's Avatar
Quoted: 24 Post(s)
Sorry but I disagree. Take a look at the lug nut you linked in post #2. It appears to have been installed on a vehicle at one time. If you look at the ring around it where it seats against the rim, you can see that the torque wasn't distributed evenly on the stud. That just can't be good IMO.
HP11 is offline
post #10 of 14 (permalink) Old 12-20-2012, 04:05 AM
With my little technical knowledge the following sentences are just a suspicion...
The surface where the pressure will rest on on the lug nut is the same, whether it is bolted straight up or a little angular. The only difference is, how the force which holds the nut to the bolt is applied. If the difference in the bolt pattern is .65mm this will transfer to a distance of .325mm for each bolt. This will result in an angle of about let's say 1-2° in which the force isn't applied axial. Torque the nut a little bit more than normal and that should do it.
If those lug nuts were a faulty design, they wouldn't sell them in Germany where you can drive as fast as you want on the Autobahn.
That's only my logical conclusion. I, for myself, wouldn't try it out on the highway, etc. without an expert assessment (e.g. TUEV-certified). I wouldn't want to loose a wheel while driving 80mph...
Hope you get what I intended to write . My english is just really really bad nowadays due to lack of exercise.
Raphi
Edit: Ok, googled a little bit. Those lug nuts are only TUEV-certified if they are used with special rims that demand them. Otherwise you won't get through inspection... For safety reasons this would be the time to say this idea was a dead-end! Safety first (yours' and for other ones')!
66MichiganTempestC is offline
Lexani Wheels Giveaway - Win a $1500 Set of Wheels! carid CARiD.com 0 04-26-2012 09:21 AM
HELP with wheels and tires.. 18x9.5" wheels?? GTOFEVR Wheels and tires 1 04-08-2010 04:12 PM
new wheels travy082 Exterior Discussions 4 04-02-2009 01:45 PM
new wheels roadracer Wheels and tires 8 02-28-2006 12:04 PM
