66 GTO wheel bearings - Pontiac GTO Forum
post #1 of 7 (permalink) Old 03-13-2011, 09:06 PM Thread Starter
I have a 66 GTO and I am trying to rebuild the rear end. I can't seem to removed the wheel bearings in the rear. It looks like there is some sort of cap possible holding it in? Am I correct that there is a cap? If so, is there a special tool to remove it?
I'm going into this project with little expierence. Any help is greatly appreciated!
Thepgavin is offline
post #2 of 7 (permalink) Old 03-14-2011, 09:14 AM
Quoted: 98 Post(s)
First, get a manual. Seriously. Or go online for diagrams. You rotate the axle flange and the hole in the flange will allow you to unbolt the 4 bolts that hold the backing plate and axle retaining plate to the rear housing. The axle just slides out. If stubborn, put the brake drum on backwards, hand tighten a couple of lug nuts, and use the drum as a slide hammer. You will need a machine shop to press off the old bearing retainers and bearings and to press on new ones. If the third member or carrier(ring/pinion/spider gears)is not making noise and the gears look fine, I would leave well enough alone. They are generally trouble free and last a long time.
post #3 of 7 (permalink) Old 03-18-2011, 05:18 PM
there are no wheel bearings on a stock rear ends. the bearing you find are axle bearings that are press fit on
pontiac is offline
post #4 of 7 (permalink) Old 03-18-2011, 11:56 PM
GTO Fanatic's Avatar
I've done this procedure several times. Now it's time to replace the axles, which I've found new at several vendors. However, I would like to buy new retaining flanges and am having a hard time finding them. Anyone know of a source?
GTO Fanatic is offline
post #5 of 7 (permalink) Old 03-19-2011, 08:46 AM
Maybe Moser? They supply really nice axles, "lifetime warranty", and they actually HONOR that! Seems to me, they build "complete" rear axle assemblies, which would include new retainer plates.
Jim
Mr. P-Body is offline
post #6 of 7 (permalink) Old 03-19-2011, 11:37 AM
Jim
I put a complete Moser rear axle in my 69. It included a new housing, a pair of their 'bullet proof" high spline count axles, bearings... everything. I'm not going to have to worry about shredding it
post #7 of 7 (permalink) Old 03-19-2011, 12:16 PM
I've tried Moser, Strange Engineering, Richmond Gear Auburn Gear, Motive Gear, Ames Performance Engineering, OPGI, RaTech, AlloyUSA, Superior Axle and Classic Industries. I'm building an extra set of axles as the rear wheel bearings seem to be a weak spot for the 64-67 GTO's. I had 3 spun axle bearings out of 4 I pulled from both my '66 and '67 GTOs. I had a set welded and turned, but it's cheaper to buy new axles. Ames, AlloyUSA, Superior Axle and OPGI have the axles. I went with Superior as they have realistic pricing on shipping. RaTech has great price on bearings and seals. I tried a national parts store for bearings, but price was 3 times as costly and they are junk. Still haven't found the retainer plate.
Pinion Bearings Chicagoat04 2004-2006 GTO General Discussion 0 02-15-2011 02:43 PM
will a alternator with bad bearings make a engin overheat? danthepontiacman 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 04-16-2010 07:51 AM
Main Bearings MaL 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 01-30-2010 02:57 PM
$499.99 GTO Hub Bearings - Matched Set [email protected] Drive train, suspension, alignment and brakes. 0 08-09-2008 06:23 PM
