67 GTO wheel stud size - Pontiac GTO Forum
post #1 of 4 (permalink) Old 05-05-2016, 05:39 PM Thread Starter
I have a 67 GTO disc brake front that I just added 17 in American racing wheels to. The wheel and tire combo fit fine however the studs appear to be to short I only seem to be grabbing a couple of threads on both the front and rears any idea of where I can get longer studs. its an original brake setup
CT67GTO is offline
post #2 of 4 (permalink) Old 05-06-2016, 08:57 AM
Welcome to the forums!!
According to my NAPA PROLINK
Front:
Wheel Bolt Knurl Dia. : 0.564"
Wheel Bolt Shoulder Length : 0.375"
Wheel Bolt Thread Size : 7/16-20
Wheel Bolt Threads : Right Hand
Rear:
Wheel Bolt Knurl Dia. : 0.472"
Wheel Bolt Shoulder Length : 0.34375"
Doesn't really say how long they are, I would pound one out and take it in to a parts store and get one longer and test it out. Maybe spray something on the inside of the nut so you can see how far down the stud it's going.
post #3 of 4 (permalink) Old 03-25-2017, 08:28 PM
Quoted: 4 Post(s)
What is the wheel & tire combo you mounted?
What did you end up doing with the studs?
GTOKurt is offline
post #4 of 4 (permalink) Old 03-28-2017, 07:00 PM
Quoted: 404 Post(s)
You may want to go to Summit or Jegs and order longer "race" studs. Check out the Moser studs. Measure your studs overall length and then see what Summit has in order to get the length you need. https://www.summitracing.com/search/...1&N=4294915045
PontiacJim is online now
Front Wheel Stud Size??? EClapp3 Wheels and tires 4 10-28-2014 05:39 PM
Wheel and Tire size for 65 GTO ningals3223 1964-1974 Tempest, Lemans & GTO Wheels & Tires 0 09-25-2011 01:16 PM
Wheel stud broke Weisberg16 Wheels and tires 4 09-12-2011 05:06 PM
Wheel Stud JCarr Drive train, suspension, alignment and brakes. 1 05-06-2011 09:25 PM
Question in regards to wheel size on a 65 GTO inaforty 1964-1974 Tempest, Lemans & GTO Wheels & Tires 8 12-03-2007 07:50 PM
