68 GTO Fender Rubbing 17x8 rims 235/50/17 tires - Pontiac GTO Forum
post #1 of 2 (permalink) Old 07-15-2015, 12:18 PM Thread Starter
As described in The title I am having rubbing issues with my 17x8 rims with 4.5 backspace and 235/50/17 tires. I'm at a loss of what to do without modifying the fenders.
I have the disc brake conversion kit in the front. The front barely rubs, but after having an alingment the rear is grabbing on the right hand side and the front is rubbing slightly worse. Does anyone have any idea what I might be able to do without modifying the fenders?
stuntmanw is offline
post #2 of 2 (permalink) Old 02-22-2016, 09:30 PM
I just did the disc brake conversion and installed 235-55-17 tires on REV Classic 17-7 with 4.5 backspace and even lowered the car 1" although I haven't aligned it yet I have 3/4" to 1" clearance front and back. You may have to go to a 7" wheel. On the back I have 275-50-17 Nittos on 17-9 rims with a 5.5 backspace these tires fit with 1/2" clearance between the quarter and tire and fill the entire well.
frankrp is offline
How much drop with 40mm os 17x8 ans 245/45-17 tires ? pcviper13 Drive train, suspension, alignment and brakes. 3 05-08-2010 08:19 AM
will 18x8.5 235/40/18 fit w/o rubbing? Hot Sauce 2004-2006 GTO General Discussion 3 03-22-2005 01:01 AM
New GTO with Squeak Up Front - Tires Rubbing? codebluemd 2004-2006 GTO General Discussion 2 12-31-2004 06:26 PM
