Backspace Mismatch Question - Pontiac GTO Forum
post #1 of 5 (permalink) Old 12-10-2013, 12:40 PM Thread Starter
I am interested in replacing the spare (or 5th, if you will) wheel for my vehicle as the current one has a leak (its not the tire). The backspace on the original 14 x 6 steel wheels appears to be 4 3/8". Most after market wheels seem to indicate a backspace of either 4", 4 1/4", or 4 1/2". I am interested in comments/opinions as to how critical it is to have the wheel backspace identically match on a particular axle (ie, front or rear) as regards to handling, etc.
To be noted, one of the wheels on the vehicle was replaced a number of years back, and I recently noted that it appears to only have 4" backspace. I haven't noticed any huge problems, so I suppose I've somewhat answered my own question, but I would like to know what others think. If you have a mismatch front, would you expect some degree of pulling or other issue?
TIA
1970 Lemans is offline
post #2 of 5 (permalink) Old 12-10-2013, 09:40 PM
jetstang's Avatar
As long as the tire fits and doesn't rub, backspace isn't an issue, especially if it's just the temp spare. It doesn't change alignment at all.
Burning rubber since 1982!!
jetstang is offline
post #3 of 5 (permalink) Old 12-11-2013, 08:45 AM Thread Starter
I can see that it won't affect caster, camber or toe-in specs.
I guess what I was wondering is the affect of the vehicle stance seemingly being off center at the axle having the mismatch. But maybe the effect may be so subtle that it is no more impactful than having one person in the front seat?
post #4 of 5 (permalink) Old 12-11-2013, 11:16 AM
Are you sure you're measuring right? Check this page.
https://www.rsracing.com/tech-wheel.html#backspace
post #5 of 5 (permalink) Old 12-11-2013, 11:31 AM Thread Starter
Yes, I measured the old (original) wheels and the replacement wheel in exactly the same fashion and just as indicated in your reference ... very useful reference BTW.
water pump and pulley mismatch Joust 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 05-25-2011 01:55 AM
What Size Backspace on 69 Ozzmann 1964-1974 Tempest, Lemans & GTO Wheels & Tires 2 11-18-2009 05:34 AM
A\C Question (taking out) & Bumper Question Lukeduk1980 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 5 08-25-2009 08:21 PM
