Conflicting Tire Advice - Pontiac GTO Forum
post #1 of 7 (permalink) Old 05-05-2017, 12:39 PM Thread Starter
I have a 65 GTO with 215/60/15 radials in the front and 255/60/15 in the back. I want to add radial redlines, 215/70/15 in the front. Coker said that even though I'm going from a 25.6 diameter to a 26.9 diameter I will have room because the tire is taller and will not rub fender. DiamondBack said that I need to stick with a 60 aspect ratio. Who is right? Below are pictures of my current situation.
ID:	90441   Click image for larger version
ID:	90449   Click image for larger version
ID:	90457   Click image for larger version
Stanjco is offline
post #2 of 7 (permalink) Old 05-05-2017, 02:48 PM
1968gto421's Avatar
Quoted: 72 Post(s)
I don't really have a good answer to this. However your wheels, tires and tire sizes (same as mine), etc. so much resembles mine except I have a '68 with Cragars.
Name:	1968 GTO Alice 13.JPG
1968gto421 is offline
post #3 of 7 (permalink) Old 05-05-2017, 02:54 PM Thread Starter
Stanjco is offline
post #4 of 7 (permalink) Old 05-05-2017, 07:15 PM
Joe'sToy's Avatar
Hi,
I have a '65 as well. I was running 235/60/15 up front and out back, front was constantly rubbing. I put 225/60/15's up front and left the 235/60/15's on the rear. Haven't had any rubbing since, even with three heavy old farts in the car with me. Hope it helps.
Joe'sToy is offline
post #5 of 7 (permalink) Old 05-05-2017, 07:39 PM Thread Starter
Thanks Joe! Beautiful Goat! Do you thing 215/65 will be cutting it close? I don't want to make $500 mistake. Lol
Stanjco is offline
post #6 of 7 (permalink) Old 05-06-2017, 10:52 AM
Joe'sToy's Avatar
I would stick with the 60 aspect. That way you shouldn't have any issues with the new tires. You may get away with the taller side wall at 65, but when you have a couple of friends in the car with you, I think your gonna rub when turning or going over speed bumps or curbs. JMO.
If you decide to go after market on your suspension, then you can fit anything, almost.
Joe.
Joe'sToy is offline
post #7 of 7 (permalink) Old 05-06-2017, 09:10 PM
Georgpn1's Avatar
In the for-whatever-its-worth category: I also have a '65 GTO with P215/65R15 on the front and P295/50R15 on the rear (on Crager SS wheels) and have no rubbing issues.
Georgpn1 is offline
69 GTO tire advice Lawson 1964-1974 Tempest, Lemans & GTO Wheels & Tires 1 01-24-2016 03:03 AM
Tire and Wheel advice -stock 65 GTO sdrake 1964-1974 Tempest, Lemans & GTO Wheels & Tires 2 04-29-2012 10:45 PM
Wheel/Tire advice needed for '65 GTO project Fred007 1964-1974 Tempest, Lemans & GTO Wheels & Tires 2 04-24-2012 07:48 PM
fresh new stance / need wheel tire advice harp 1964-1974 Tempest, Lemans & GTO Wheels & Tires 3 04-24-2012 08:10 AM
Transmission Fluid Amount. New conflicting information. 06goatm6 Service, Maintenance and Technical Discussion 1 02-12-2009 11:56 PM
