Factory PSI in bias-ply tires on '70 GTO? - Pontiac GTO Forum
post #1 of 3 (permalink) Old 09-13-2011, 03:43 PM Thread Starter
Trying to locate a photo online of a door jamb decal of the recommended factory tire pressures for the original bias-ply tires on a '70 GTO. I bought this car with F70-15 Firestone Wide Oval reproductions on it and would like to know what the original recommended pressure was.
Searched the forums and found nothing on this exact topic. I have seen several '70 Chevelle door jamb decals that show 26psi cold front/rear, and since that car weighs about the same (~3700lbs) and F70-15s were available on those cars, is it fair to assume 26psi is the right number? The sidewalls on my F70-15s say 'max pressure 32psi' and the Chevelle decal does show "26psi cold / 32psi hot"...
Thanks in advance!
Bobby
in Las Vegas
ZGstar is offline
post #2 of 3 (permalink) Old 09-13-2011, 07:33 PM
correct decal is available for Pontiacs. usually in owner's manual as well.
pontiac is offline
post #3 of 3 (permalink) Old 09-14-2011, 09:28 AM
...28 cold-32 hot is where you should be. Eric
Eric Animal is offline
Factory Tires SPICERED2006 Wheels and tires 11 11-26-2007 12:51 PM
