Front wheel and tire fitment and trunk pan question - Pontiac GTO Forum
post #1 of 3 (permalink) Old 04-15-2014, 07:57 PM Thread Starter
Getting ready to order my wheels and tires need info on largest 18 in front tire and rim I can use I would like as large lip as possible, will be using AFX spindle wildwood brakes and not sure on brand of A Arm set up yet any info?
Also my trunk area has crater pitting but no holes through the trunk should I replace this area or is it oh to use filler?
Alaska GTO is offline
post #2 of 3 (permalink) Old 04-18-2014, 08:11 PM
crustysack's Avatar
you should try protouring.com website for this info lots of knowledge there for larger rims on classic cars
crustysack is offline
post #3 of 3 (permalink) Old 04-22-2014, 06:02 PM
i encourage you to do very thorough research on this one.
there are many, many threads out there which describe situations where wheel and tire package was ordered long before final ride height was established.
of course, problems result when it's not done right the first time.
if you look around online you may be able to find a build similar to yours with some clues about which set-up offers good fitment.
in my opinion the best way to handle this issue is to find a cheap "roller" package to ride on until final ride weight and height are established. then, determine how wide you want your tires, measure for backspacing and calculate offset to get exactly what is required for best fitment.
best of luck getting it figured out...
danny
1968 GTO Resto-Mod is offline
Beyern 5 front wheel fitment question 04impulseblue Wheels and tires 0 06-02-2012 05:38 PM
Trunk pan question par4n1 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 1 12-08-2011 01:12 AM
18x8 wheel / tire fitment question 06black60 Wheels and tires 10 09-27-2008 09:07 PM
Wheel/Tire fitment questions..... CUZ-I-CAN Service, Maintenance and Technical Discussion 15 05-17-2005 12:55 AM
Wheel and Tire Package Fitment Question Judged 2004-2006 GTO General Discussion 1 05-06-2005 12:34 PM
