Help with wheel size... - Pontiac GTO Forum
post #1 of 3 (permalink) Old 08-15-2012, 02:03 PM Thread Starter
I'm shopping for wheels right now and need to know if this spec will fit.
I have a 68 tempest
20x8.5 size
5x120.65mm 5 lug
14mm offset
5.25 backspacing
The wheel style in eBay is boss 304
Inda_bebe is offline
post #2 of 3 (permalink) Old 08-16-2012, 09:05 AM
Find and buy yourself a "Percy's Wheelrite" tool and make your own measurements. There can be variances on the same car, even the same year/make/model (previous body damage, panel alignment, etc.) that make it impossible for someone to 'guarantee' whether or not any given wheel/tire combo will fit.
post #3 of 3 (permalink) Old 08-16-2012, 09:51 AM
Maybe check with a local tire/wheel store and see if they have a Wheelrite you can borrow/rent. I have a friend who has one and it allowed my to stuff maximum rubber under my wheelwells.
Like Bear said too, the tires all have different profiles and bulge depending on the manufacturer and the size wheel you use. The wheel size you list should work based on the specs given but I'd want to be 100% sure before I laid out the cash.
65 GTO Max wheel size??? faze07hd 1964-1974 Tempest, Lemans & GTO Wheels & Tires 5 07-07-2010 07:19 PM
Wheel size ppurfield001 1964-1974 Tempest, Lemans & GTO Wheels & Tires 4 01-22-2009 06:26 PM
Wheel rim size GTODAVE05 Service, Maintenance and Technical Discussion 3 06-16-2005 10:20 PM
Wheel size ? guyman 1964-1974 Tempest, Lemans & GTO Wheels & Tires 1 06-07-2005 09:06 AM
What size DRAG's will fit 05 GTO wheel????? newagegoat Service, Maintenance and Technical Discussion 11 05-16-2005 11:37 PM
