How do I stop wheel hop? - Pontiac GTO Forum
post #1 of 20 (permalink) Old 10-04-2012, 07:50 PM Thread Starter
mbergin's Avatar
Quoted: 8 Post(s)
Hi all,
Just tuned my 69 and she runs awesome. When I'm sitting still or on a slow roll and hit it, all I get is wheel hop. Looking to burn some rubber from the tires but not having much luck. Any thoughts. Will a rear sway bar help?
mbergin is offline
post #2 of 20 (permalink) Old 10-05-2012, 08:09 AM
Sway bar probably won't help that. What's your rear suspension setup like... factory arms and rubber bushings?
post #3 of 20 (permalink) Old 10-05-2012, 02:57 PM
Quoted: 98 Post(s)
Usually, a lifted rear suspensionis the culprit. There are no -hop devices available if you want to run with it jacked up in the rear and want to eliminate hop. Stock suspensions usually are pretty good about not hopping. It's all about pinion angle and load. Google No Hop bars for GM for more info.....
post #4 of 20 (permalink) Old 10-05-2012, 07:22 PM Thread Starter
mbergin's Avatar
Quoted: 8 Post(s)
Thanks for the replies. Factory areas and rubber bushings it is. Rear sits a little low especially with a full gas tank even though the spring are new (previous owner installed). Kinda don't want to put anything that will make it all jacked up in the rear. I'll take a look at what's available on the web. I was hoping this would be an easy fix.
mbergin is offline
post #5 of 20 (permalink) Old 10-05-2012, 10:24 PM
Have you thought about drag bags?
05GTO is offline
post #6 of 20 (permalink) Old 10-06-2012, 05:53 AM
Here's the answer to all your suspension questions http://www.dickmillerracing.com
I actually typed out a rather long answer yesterday morning but my computer locked up when I submitted my reply and I had to be off to work.
Flex in the stock control arms, bushings and too short of an instant center on the stock suspension is the Cliffnotes version. Dick Millers book is a great reference and he defininetly knows how to get a GM A body to hook!
Edit: Some people might call him "Richard" Miller lol. Dang profanity editor .
post #7 of 20 (permalink) Old 10-06-2012, 07:42 AM
Originally Posted by ALKYGTO View Post
Here's the answer to all your suspension questions _ Oldsmobile, Suspension GM & Cutlass & Chevelle & Ford: Dick Miller Racing Oldsmobile Performance Parts.
I corrected the problem with the censor,
05GTO is offline
post #8 of 20 (permalink) Old 10-06-2012, 06:22 PM
Thanks.
post #9 of 20 (permalink) Old 10-06-2012, 07:37 PM
My first suspicion would be the rubber bushings, especially if they're old and worn. A fresh set might tighten things up 'just enough'. With factory control arms though you DON'T want to put in hard urethane bushings. The geometries involved would make everything want to bind up in turns, maybe bending/breaking things. The real fix is to replace the factory arms with aftermarket pieces that have some sort of spherical joints on the ends (OK if they're just one one end for the uppers). This kind of joint will take all the fore/aft "slop" out of the arms (that's what's causing your wheel hop) while allowing a much more free movement of the suspension in all the directions that it's supposed to move. I'm running Spohn pieces on my car.
post #10 of 20 (permalink) Old 10-06-2012, 08:08 PM
Quoted: 98 Post(s)
There are no-hop brackets that attach to the diff housing at the center section and they are undetectable when the car is sitting on the road. They have been around for decades, and they work great with a stock suspension. They are not traction bars or ladder bars, merely brackets that keep the diff from winding up and changing the pinion angle on hard acceleration. I would go with those, or Air Lift air bags. Cheap and easy, if all you need is to stop wheel hop but don't want to modify the suspension.
Starter wont stop Indy1K 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 08-14-2010 07:42 PM
Shifter stop or not 04Cosmo Drive train, suspension, alignment and brakes. 8 02-20-2009 08:58 PM
Priceless police stop fergyflyer Audio & Video Clips 6 05-25-2008 03:25 AM
I can't stop thinking about her... s2gordon The Lounge 6 08-13-2006 09:42 PM
How do ya stop the wheel hop carguy Service, Maintenance and Technical Discussion 8 12-17-2004 10:53 PM
