New Tires and Rims for 1965 GTO - Pontiac GTO Forum
post #1 of 13 (permalink) Old 10-23-2014, 05:43 PM Thread Starter
I am getting 15x7 Ralley 1 rims for the GTO so it will accommodate front disc brakes. Now for the tires. I don't want them to rub so what would be the largest tire I could get? I was thinking of getting 225 70 R15s? Would that be a good choice? Seems like I saw that it was somewhere on the forum here. Ralley 1s are from National Parts Depo.
poocher is offline
post #2 of 13 (permalink) Old 10-25-2014, 04:37 PM
rickm's Avatar
Quoted: 5 Post(s)
good question. Im curious to see what size 15" tires '65 owners are running. ive got 215 65 R15 T/A radials on 15x7 torque thrust mags with a GM single piston disc brake kit. when the outside edge of the tire passes by the front lip of the fender, you can barely get a matchbook between the tire n fender. kinda too close for comfort.
rickm is offline
post #3 of 13 (permalink) Old 10-26-2014, 01:23 AM
eeyore's Avatar
eeyore is offline
post #4 of 13 (permalink) Old 10-30-2014, 09:54 PM Thread Starter
Tire Rub
Well I went ahead with the tire purchase and sure enough the 225-70-R15s have a rub when I make a sharp turn. It doesn't seem to be that bad but I cant have a rub. So, it's either new fronts or some sort of spacer I'm told I could try. Too bad though I really liked the look of the tires. Rear of course is not a problem...just the front.
poocher is offline
post #5 of 13 (permalink) Old 11-02-2014, 12:51 AM
Quoted: 106 Post(s)
The recommended tire size is 225/60-15 the 225/70 is a little bit taller.
I just ordered a set of 225/70-15 redlines for my 67 because I couldn't find redlines in 225/60.
I have 235/70-15s on it right now but the rear passenger side rubs on the fenderwell with 4 people in the car.
The front tires also rub slightly going onto off camber aprons but I can avoid the rubbing by swinging out wide and going onto them at a straighter angle.
Goat Roper is offline
post #6 of 13 (permalink) Old 11-02-2014, 07:44 AM
rickm's Avatar
Quoted: 5 Post(s)
no spacer. 60s on the front will give you enough clearance from the bottom lip of the fender with 15x7 wheels.
rickm is offline
post #7 of 13 (permalink) Old 11-02-2014, 07:49 AM
SANDU002's Avatar
I have 215x70x15's on my '65. Coker redlines. If you contact Coker, I'm sure they can get you 225x60 redlines.
67 Post Coupe,
69 RA III Judge
06 BOM, M6, 18's
SANDU002 is offline
post #8 of 13 (permalink) Old 11-02-2014, 12:11 PM Thread Starter
What about??
Thanks for all of your replies. That helps out a lot! A seasoned guy who does brake conversions told me that after I put on my disc brake conversion I may find out that I don't have a rub since the disc brake conversion will push the tires out a little. Anybody think I have a shot with this or should I just order two new fronts ....225 60 R 15s?
poocher is offline
post #9 of 13 (permalink) Old 11-02-2014, 01:09 PM
Quoted: 106 Post(s)
Changing to disc brakes doesn't change the aspect ratio of the tires, I converted to disc brakes and the tires still rub.
I just got off the phone with Summit and apparently Coker isn't making the /60 redlines they show as discontinued on the Coker site.
post #10 of 13 (permalink) Old 11-02-2014, 01:33 PM
the65gto's Avatar
Quoted: 12 Post(s)
When I converted my 65 to disc, I had aftermarket 14" rims (Keystone Klassic)that did not rub the front caliper because of their offset. It was close, but ordered/updated to 15" aftermarket rims and chose the offset that relatively put the tire (235x60x15)in the middle and had plenty of clearance to the caliper.
the65gto is offline
Rims/Tires for gto...? jmitch2604 Wheels and tires 4 03-30-2012 04:53 PM
how to put 2006 GTO rims on a 1965 torpedo51 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 0 01-22-2012 03:09 AM
need advice about rims and tires for 68 gto matt68gto 1964-1974 Tempest, Lemans & GTO General Discussion 7 06-18-2006 09:55 PM
Vette Rims/Tires on a GTO? StocktonRaider 2004-2006 GTO General Discussion 0 07-28-2005 08:23 PM
