new wheels for my gto - Pontiac GTO Forum
post #1 of 22 (permalink) Old 11-24-2011, 07:00 PM Thread Starter
Hi!
I'm looking for some new wheels for my 66 GTO.
I found 3 that I like, but I don't know which fits best and I'm not sure which one will look best
1.) Cragar SS 2piece
Cragar 61715 - Cragar 08/61 S/S Super Sport Chrome Wheels - Overview - SummitRacing.com
2.) Cragar SS 1piece alu
Cragar 610C573442 - Cragar S/S 1-Piece Aluminum Chrome Wheels - Overview - SummitRacing.com
3.) American Racing Vintage
American Racing T71R5761 - American Racing Vintage Series T71R Polished Wheels - Overview - SummitRacing.com
All are 7x15" with difference in offset (0 to +6).
The #1 will need some other wheel lug nuts, because it has a bolt circle of 5x4,5/4,75/5.. can someone tell me which ones I need at summit? I only know my GTO has 5x4,75.
What do you think??
Chris-Austria is offline
post #2 of 22 (permalink) Old 11-24-2011, 08:03 PM
Quoted: 23 Post(s)
i like the Billet Cragars, after getting mine i will never buy a chrome wheel again.
Instg8ter is offline
post #3 of 22 (permalink) Old 11-24-2011, 08:10 PM
Quoted: 16 Post(s)
Yeah, +1 on #2, the steel Cragars rust. And they will look Awsome on your car. I like the #3 wheels but they've just been played out, everybody has them it seems, but still a good choice that won't go out of style.
Instigator, your missing a few lugnuts.......
post #4 of 22 (permalink) Old 11-25-2011, 06:38 AM Thread Starter
Thats a good information, does anyone have the #2 on his car? Didn't see them yet, where I live are not too much GTO's with chrome rims
@instg8ter
Your wheels also look very good, if you can show me some other wheels that I haven't found I'd be happy for links to them at summit (I'd like to order them there..)
But I really like chrome
post #5 of 22 (permalink) Old 11-25-2011, 10:07 AM Thread Starter
Can you tell me what wheel this is?
I think it's a RallyII, 15".
On the backside there is nothing written down what size it has. On the front there is a small 7 and a small 4 to the left and right of the valve.
I mounted it on my car an it fits just perfect, no scratching at all like with my torque thrust. Width and offset/backspace would be very interesting... maybe its 7x15 with 4" backspace?
post #6 of 22 (permalink) Old 11-25-2011, 10:11 AM
Quoted: 23 Post(s)
hey Chris this is the manufacture that made my wheels, if you look they have a rally 2 in billet i think Eric is using on his car. Summit also carries them although i think their choices are limited. you will want 4.5 " backspace on the rims.
Billet Specialties
post #7 of 22 (permalink) Old 11-25-2011, 10:52 AM
Hi Chris,
That's a Rallye II wheel, but it's chrome so it's probably a reproduction. I kinow that Wheel Vintiques and also Specialty Wheel here offer several different varieties of Rallye II's, some painted like original, some chrome with silver centers, some chrome with dark charcoal centers (new).
Choosing wheels is mostly a 'taste' thing and everyone has their own opinions. Pick something you personally like and go with it - realize that there's always going to be someone out there who will think "something else" would be "better".
post #8 of 22 (permalink) Old 11-25-2011, 11:10 AM
Quoted: 16 Post(s)
Interesting center cap on that wheel.............
And to measure the backspacing, put a straight edge across the back lip of the wheel (not the bead edge, the flat surface) and measure down to the surface that goes against the axle. That will be your backspace. Do the same in the front and add the two and you should come up with the actual width of the wheel.
Also noticed the rust between the rim and center. Chrome plated steel rims look great as long as you don't subject them to dirt, moisture or..........driving. Nothing has quite the same shine as chrome, but you can have chrome plated aluminum wheels. But note that they are subject to electrallesis (sp?) when used in the weather.
post #9 of 22 (permalink) Old 11-25-2011, 11:32 AM Thread Starter
The Rally2 rim is from my trunk.. I think it's a 7x15 with 4" BS and the others are torque thrust 7x15 with 3,75" BS. The Rally don't scratch and the only difference is the 0,25" BS.. so if I buy the Cragars with 4,25" BS they must fit.
Every 7x15 with 4-4,25" BS will be fine I think.. and to keep the track wider I'll take just as much BS as needed
I will measure it to make sure that my plan will work and then order some new rims that will fit. How do you call plates between the wheel hub and the rim to make a lower offset? I might want to use them at the rear wheels because the fit perfect with 3,75" BS.
I like the #1 (steel/alu).. I don't drive the car if the streets are wet or in winter. And if I wash the rims every 1-2 weeks, do you think rust will be a problem?? They seem to have the perfect offset and style for a fair price!
post #10 of 22 (permalink) Old 11-25-2011, 05:43 PM Thread Starter
I found these rims.. they look very good and I'm sure they have the correct size! Does anyone know "Rocket Racing"? It's an aluminum wheel with chrome.. but are they worth the money? They are pretty expensive in contrast to #1-3!
HELP with wheels and tires.. 18x9.5" wheels?? GTOFEVR Wheels and tires 1 04-08-2010 05:12 PM
New wheels! deaner17 Wheels and tires 3 08-09-2009 09:42 PM
wheels off a BMW will they fit? GoatOnMeth Wheels and tires 3 06-11-2009 03:29 PM
C6 ZO6 Wheels for '04 GTO awsumvet Wheels and tires 0 01-06-2007 12:20 AM
