Performance Wheel, tire, brake, and suspension - Pontiac GTO Forum
post #1 of 2 (permalink) Old 10-26-2017, 08:06 AM Thread Starter
Quoted: 126 Post(s)
I am the new owner [STOKED] of a 1965 GTO 3 speed manual tri power. The car is pretty much stock (except I have installed 4 speed muncie) and needs some restoration (pics to follow). Currently the car has drums all around and 14" wheels. I like to really drive my cars and would like to upgrade the brakes to discs.
Questions:
(1) What setups provide the best braking - kits or pieced together and best disc size ?
(2) Have many folks converted over to a hydra boost setup and if so any details on the items needed ?
(3) I am guessing that most brake upgrades with the exception of the kit on AMES will require a bigger wheel. From a performance standpoint, I would like to have as light a wheel / tire package as possible, but still have a lot of rubber on the ground. What is the biggest wheel / tire combination I can fit on a 65 convertible?
(4) Should I consider making suspension changes to the car (dropped spindles or other) ?
Thanks in advance for your help!
Chris
cij911 is offline
post #2 of 2 (permalink) Old 10-26-2017, 02:59 PM Thread Starter
Quoted: 126 Post(s)
Bump for help....35 views and no replies .....I know tons of people have been down this path and I don't want to reinvent the wheel. Thanks
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is offline
whats the widest staggered wheel / tire combo that can fit w/ aftermarket suspension? blackwidow Wheels and tires 7 02-20-2013 10:04 AM
Performance suspension packages GhostTown 1964-1974 Tempest, Lemans & GTO General Discussion 17 01-17-2013 02:31 PM
Brake Performance BlackJackByte Drive train, suspension, alignment and brakes. 6 07-12-2010 03:17 PM
What's your alignment settings for your suspension and wheel/tire setup? batmans Drive train, suspension, alignment and brakes. 4 03-17-2010 11:05 AM
