Question about wheel and tire size - Pontiac GTO Forum
 5Likes
  • 1 Post By Don Oliver
  • 2 Post By Joe'sToy
  • 1 Post By Joe'sToy
post #1 of 9 (permalink) Old 02-18-2018, 09:29 PM Thread Starter
What is the widest wheel and Tire that I can fit in the back of a 1965 Lemans without cutting anything. I want to run a 18 x 9 or 18x10 is this possible. I would also like to run a 18x7 or 18x8 in the front. Thanks Don
GoatSilver likes this.
Don Oliver is offline
post #2 of 9 (permalink) Old 02-28-2018, 07:38 AM
Quoted: 126 Post(s)
I have found AR Torq II that will work - 18x8 & 18x10" in the rear. It also depends on what tire you run and your stance....Good luck
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is offline
post #3 of 9 (permalink) Old 04-06-2018, 07:41 AM
Quoted: 126 Post(s)
Bump for more guidance / feedback.....What about adding a mini tub - does that really buy anything or is the real limiting factor the rear frame and suspension ?
Current setup:
4 speed Muncie
cij911 is offline
post #4 of 9 (permalink) Old 06-07-2018, 12:57 PM
I would love to know the answer to this one too. Thanks!
Aika1 is offline
post #5 of 9 (permalink) Old 06-07-2018, 06:51 PM
Joe'sToy's Avatar
Ok, I just went through this, I went with a 17x9 in the rear and 17x8 in the front. BS in the front 4.75" and in the rear 5.00" Tires are Nitto 555's, 275x40x17 in the rear and 225x45x17 in the front. I have absolutely no rubbing in the front or rear. Tires are also redlines from Diamond back.
GoatSilver and cij911 like this.
Joe'sToy is offline
post #6 of 9 (permalink) Old 06-07-2018, 06:57 PM
Joe'sToy's Avatar
Site only allows one of my pic's!
Name:	New rims and tires 2.jpeg
cij911 likes this.
Joe'sToy is offline
post #7 of 9 (permalink) Old 06-08-2018, 07:19 AM
Quoted: 126 Post(s)
Joe - Can you post more pictures of your car? You should be able to upload 5 per post - select "go advanced", then scroll down, select manage attachments, then you should see a box that allows you to select and upload 5 pictures, make sure to upload, close the new box, and submit thread.
Would you please post a few side shots (straight on) of you wheels and tires ?
Also, did you try 245/45/17 in the front ? I was hoping to go 245/45/17 in the front to keep a close to 26" rolling diameter. I guess the 225/45 will give the car a naturally raked look though (albeit ~ 1/2" drop).
Chris
Current setup:
4 speed Muncie
cij911 is offline
post #8 of 9 (permalink) Old 06-08-2018, 12:00 PM
Joe'sToy's Avatar
Chris
Hi Chris,
I will try to post more pics in a bit. Last evening the site was telling me error with uploads and could only get the one pic to load. As for your questions, the rear tires are at the max, with stock suspension, they fill the wheel well nicely, can just get a fingers width between wheel lip and tire. The inside is about 3/4" clearance of the frame and suspension, no rubbing or issues with the control arms or drums. The fronts have plenty of room, probably could have gone with a 235/45/17 and still be no issues, but didn't want to chance it with the cost of the redlines.
cij911 likes this.
Joe'sToy is offline
post #9 of 9 (permalink) Old 06-11-2018, 06:20 AM
Quoted: 126 Post(s)
Originally Posted by Joe'sToy View Post
Hi Chris,
Thanks Joe!
I am hoping to run 245/45/17 up front & 275/40/17 rear.
Which wheel setup did you go with as well ?
Current setup:
4 speed Muncie
cij911 is offline
Wheel size and tire size Jarzone Wheels and tires 2 03-04-2016 01:19 PM
Tire and wheel size gtohrdtp 1964-1974 Tempest, Lemans & GTO Wheels & Tires 5 10-18-2015 09:58 PM
Wheel and Tire size for 65 GTO ningals3223 1964-1974 Tempest, Lemans & GTO Wheels & Tires 0 09-25-2011 12:16 PM
wheel and tire size limits charlie4170 1964-1974 Tempest, Lemans & GTO Wheels & Tires 11 05-20-2011 11:17 AM
Tire & Wheel Size RajunCajun 2004-2006 GTO General Discussion 3 11-12-2004 06:24 PM
