Rims and tires on my 69 gto - Pontiac GTO Forum
post #1 of 3 (permalink) Old 04-24-2016, 06:44 PM Thread Starter
I'm currently have p245 60r 14 good year Eagles there on a set of crager 14x6 rims
I'm looking to get new rims going with American racing torq thrust 15x7 what I'm looking at tire size was going to be 255 60r 15
Will this be too big to fit on the stock suspension should I maybe be looking at 50r instead ?
I do have an appointment set up to take some measurements but want to know I guess if it will look silly as in too big .
I'm looking for a slightly larger size to to give it a nicer stance .
Thanks !
Lawson is offline
post #2 of 3 (permalink) Old 04-24-2016, 07:17 PM
Hi Lawson,
This topic has been discussed on here many times. You'll probably be able to find several threads with a quick search. Short answer: There's enough variance from car to car (even the same year and model --- differences at the factory, prior collision damage, etc) that no one can guarantee what will fit and what won't - especially when you're trying to push it to the limit. The only way to know for sure is to measure YOUR car with a tool made for such purposes, such as a Percy's WheelRite.
post #3 of 3 (permalink) Old 04-24-2016, 09:15 PM Thread Starter
Perfect thanks . I have an appointment set up to check .. I noticed an old post by you on your 69 running p245-60 15 I think I will be going with that set up
245-60 15 front and 255-60 15 rear as long as my measurements allow it
Thanks !
Lawson is offline
New Tires and Rims for 1965 GTO poocher 1964-1974 Tempest, Lemans & GTO Wheels & Tires 12 11-10-2014 12:27 PM
Rims/Tires for gto...? jmitch2604 Wheels and tires 4 03-30-2012 03:53 PM
need advice about rims and tires for 68 gto matt68gto 1964-1974 Tempest, Lemans & GTO General Discussion 7 06-18-2006 08:55 PM
Vette Rims/Tires on a GTO? StocktonRaider 2004-2006 GTO General Discussion 0 07-28-2005 07:23 PM
