Test fit some wheels and tires on the 64 - Pontiac GTO Forum
post #1 of 4 (permalink) Old 09-28-2017, 02:19 PM Thread Starter
I test fit some wheels and tires on the 64 GTO I'm rebuilding and was very surprised at the size I could tuck under the rear.
Old school/new school mixture, Torque Thrust II wheels
Front tested is a 18x8 with zero offset and a 235/40r18 I like a little more meat on the rim so I'm going to upsize to a 245/40r18
Rear tested is a 20x10 with 6mm offset (5.75" bs) and a 275/40r20. This fitment is fantastic and will not rub. My one complaint is that there aren't many cast wheels with a 6mm offset so choices go way down. Most 20x10s you will find are zero offset which is 5.5" backspace. They might fit, but it would be extremely tight without the 6mm offset.
On to a few pics.
Name:	2017-09-27 10.12.04.jpg
ID:	97114   Click image for larger version
Name:	2017-09-27 10.14.30.jpg
1964SS is offline
post #2 of 4 (permalink) Old 10-26-2017, 04:02 PM
Quoted: 162 Post(s)
That looks hot !! Is that on a stock suspension ?
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is offline
post #3 of 4 (permalink) Old 11-01-2017, 09:37 AM
Quoted: 162 Post(s)
On to a few pics.
Do you have weights for the wheels and / or wheels and tires ?
How do you think 17 & 19s would look (vs. 18 & 20) ? I'd rather run a bit more sidewall for comfort and looks. Either way, going 17" + will allow me to run c5/c6 brakes, which I want to install for safety / performance.
Current setup:
4 speed Muncie
cij911 is offline
post #4 of 4 (permalink) Old 11-01-2017, 05:30 PM Thread Starter
The pictures are on one inch lower in front and stock rear. I've recently lowered the rear an inch as well. 17's or 18's would look awesome. I've seen several with 18's on all four and I like that look a lot.
1964SS is offline
Got Tires but need Rims to fit evanpatchay Wheels and tires 7 05-26-2014 12:43 PM
Hood test fit on my 65 SDGoat619 1964-1974 Tempest, Lemans & GTO General Discussion 2 04-08-2013 08:36 PM
Will these tires fit!! Jcoin Wheels and tires 2 06-26-2009 05:38 PM
hope these tires will fit wildchildm39 Service, Maintenance and Technical Discussion 3 08-31-2005 05:16 PM
