Thoughts on Tire Size - Pontiac GTO Forum
post #1 of 5 (permalink) Old 09-23-2016, 07:17 AM Thread Starter
Quoted: 4 Post(s)
Good Day All
Looking at purchasing some taller tires for a '66 GTO (389 tripower /4 speed).
For 14" rims I can find a 26.7 diameter tire (215/75R14)
For 15" rims there is a 28.8 (225/75R15)
29.0 (235/75R15)
The end game is to slow down the engine rpm's.
My question is fitment. Any one out there with knowledge as to any clearance issues with these selections?
All comments welcomed.
Omni
Omni is offline
post #2 of 5 (permalink) Old 09-23-2016, 10:03 AM
You want to reduce the engines RPM by increasing tire size?
Why not address your rear end? What gearing are you running?
Seems to me if you increase your tire size you'll throw off your mileage calculator and overwork the engine trying to maintain the speed you travel?
Unless it's minimal figure in a re-calibration of your speedometer. My '70 was raced and had 4.33's in it when I got it, I installed the 3.55 and the RPM at 60-65 dropped from 3500 to about 28-2900. Running 14x65's. Was over by 20 mph and finding the right the speedo gear am now off 2 mph at 60 which accounts for the 65 series tire.
post #3 of 5 (permalink) Old 09-23-2016, 12:44 PM
64GTOConvertible's Avatar
Quoted: 17 Post(s)
Changing tire size does the same thing as adjusting ratio, so why not. The taller the tire, the further the car goes with each revolution. Same thing as reducing the gearing. But a speedo adjustment is going to be necessary. I'm sure there are plenty of formulas out there to help you figger out what you need at the end.
That said, I just bought tires for my '64. The 66 supposedly has more clearance, so you should be OK with 275/60 on the rear and 235/60 on the front.
64GTOConvertible is offline
post #4 of 5 (permalink) Old 09-24-2016, 09:41 AM
On listed tire dimensions, be careful trusting height numbers, as even same size very similar tire designs by the same manufacturer can have different section widths, different contact width, and different tire height when mated to the same size wheel. Ran into this over 30 years ago when auto crossing. Desiring tallest possible rear tires on a '66 cruiser, I'd look into 15" wheels, many more tire choices.
post #5 of 5 (permalink) Old 09-24-2016, 10:57 AM
1968gto421's Avatar
Quoted: 72 Post(s)
Whether or not one likes TCI Transmission, they have some great tech stuff. Here is a link to their page on figuring out speedo gear ratios and lists gears for GM tranny's.I've used it alot over the years with different setups.
Speedometer Gear Calculator and Charts - TCIŽ Auto
Luck with all this.
1968gto421 is online now
Wheel size and tire size Jarzone Wheels and tires 2 03-04-2016 02:19 PM
What size tire for a snow tire on my 04? BL3 Wheels and tires 5 11-26-2011 11:35 PM
Tire Size GuatoLT1 2004-2006 GTO General Discussion 4 01-02-2011 02:35 AM
tire size Pontiac Tempest Cstm 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 01-02-2009 08:28 AM
help tire size? gtony Wheels and tires 0 06-04-2006 01:38 AM
