Tire and wheel size - Pontiac GTO Forum
post #1 of 6 (permalink) Old 10-18-2015, 11:01 AM Thread Starter
Tire and wheel size
Will a 15x7 wheel with a 225/70-15 rub on the front fenders of 69 GTO
gtohrdtp is offline
post #2 of 6 (permalink) Old 10-18-2015, 11:16 AM
1968gto421's Avatar
Quoted: 72 Post(s)
Unsure, my '68 is very similar to yours but has the 15x7 with 215's which have plenty of clearance. Probably these 225's will fit yours.
Hopefully someone with more experience will chime in here and give you a concrete answer. (I'm certain a 225/60 will fit without clearance problems.)
Luck!
1968gto421 is offline
post #3 of 6 (permalink) Old 10-18-2015, 11:46 AM
SANDU002's Avatar
225x60/15 7" fit fine with no issue on my '67.
67 Post Coupe,
69 RA III Judge
06 BOM, M6, 18's
SANDU002 is offline
post #4 of 6 (permalink) Old 10-18-2015, 11:50 AM Thread Starter
It may work that size is about 1" smaller diameter
gtohrdtp is offline
post #5 of 6 (permalink) Old 10-18-2015, 01:23 PM
I always recommend using one of these to check tire/wheel fitment.
http://www.amazon.com/Percy-01201-WheelRite-Wheel-Simulator/dp/B002L1GFQE
Cars can and do vary. You never know when things might have moved due to prior collision damage, a 'bad day' at the assembly plant, etc. Just because a combination fits on someone else's car is not a guarantee it'll fit on yours.
post #6 of 6 (permalink) Old 10-18-2015, 10:58 PM
Layzdude's Avatar
Yes, they do rub the front fender but just barely. I have the same tire and wheel size on my "68" I am looking to go one size down in the front. Hope this helps.
John
Layzdude is offline
1967 wheel/tire size nitrous67gto 1964-1974 Tempest, Lemans & GTO Wheels & Tires 15 11-15-2013 02:08 PM
Wheel/tire size options SWGOAT Wheels and tires 0 11-08-2011 11:53 PM
Wheel and Tire size for 65 GTO ningals3223 1964-1974 Tempest, Lemans & GTO Wheels & Tires 0 09-25-2011 01:16 PM
wheel and tire size limits charlie4170 1964-1974 Tempest, Lemans & GTO Wheels & Tires 11 05-20-2011 12:17 PM
Tire & Wheel Size RajunCajun 2004-2006 GTO General Discussion 3 11-12-2004 07:24 PM
