What size BFGoodRigh TA Radial for 15 inch Rally II Wheels - Pontiac GTO Forum
post #1 of 6 (permalink) Old 01-20-2012, 01:44 PM Thread Starter
jtwoods4's Avatar
I have the Stock 15x7 Rally II wheels for my 69 GTO. I want to get some BFGoodrish TA Radials and I am not sure what the right tire size is for the front and the rear. I dont want massive rear tires and small front tires. I just want some nice standard size TA Radials. What sizes fit nicely on the 69 GTO?
jtwoods4 is offline
post #2 of 6 (permalink) Old 01-20-2012, 02:21 PM
I have 245x60x14 and the width is really nice. They are on 14X7 rims.
IMO: if you want a nice not too wide but not narrow tire perhaps the 60 series are worth looking into? I really like the width of mine. The whole car has a nice squat to it.
With 15's your s should really look good.
post #3 of 6 (permalink) Old 01-20-2012, 02:49 PM
GTO Judge, your car is a beauty! Like the 245/60's too!
1969 GTO clone, stock 400 motor and 400TH transmission
pontiacsniper is offline
post #4 of 6 (permalink) Old 01-20-2012, 04:39 PM
I'm running BFG P245/60-15's on all 4 corners of the Beast. They don't rub (now) but just barely on the front. When the fronts are about halfway through to max steering lock, the outside edge of the tire misses the front lower corner of the wheel opening by less than 1/4", but it does clear. I had a little rubbing on the left side at first until I reworked the corner of the wheel opening trim at that spot.
I think I could go a little wider on the rear with custom backspace wheels, but not by much. There's room for larger diameter, but not much wider.
ID:	13578   Click image for larger version
post #5 of 6 (permalink) Old 01-20-2012, 05:42 PM
post #6 of 6 (permalink) Old 01-20-2012, 06:45 PM
jigaway's Avatar
I have a 71 and just got some new 15 Rallye IIs. I am going to go with 235/60s in the front and 255/60s in the back. I want to fill up the rear wheel wells a bit more and make her look a little more aggressive..
Currently it has 235s all around and the rears just look too tucked under for my taste.
Dan
jigaway is offline
14x6 rally wheels what best tyre size looking for redlines fiesta62 1964-1974 Tempest, Lemans & GTO Wheels & Tires 10 10-25-2011 12:44 AM
Two Factory wheels looking for a street radial tire? 04ls1GTO Wheels and tires 3 02-28-2011 04:13 PM
14x6 Rally II Tire Size sixeightGTO 1964-1974 Tempest, Lemans & GTO Wheels & Tires 2 10-22-2010 12:43 PM
What size are the 17 inch rims and bolt pattern 01dakota59rt 2004-2006 GTO General Discussion 4 10-21-2005 02:12 PM
