wheel advice - Pontiac GTO Forum
post #1 of 5 (permalink) Old 06-10-2014, 06:43 PM Thread Starter
teamwoody72's Avatar
wheel advice
I really like this wheel for the 67. I tthink it would look good with the black vinyl top, chrome trim. I am also thinking about adding a black pinstipe. My question is (what size and backspace will work for stock setup) I am thinking 18x8 with 5" backspace in front and 18x9 with 5.75 backspace in the rear. 245-40-18 front tire and 275-45-18 in the rear. I have researched this a lot and have been told this will fit. thoughts and opinions on the wheel selection needed.
ID:	40618   Click image for larger version
teamwoody72 is offline
post #2 of 5 (permalink) Old 06-11-2014, 09:10 AM
Quoted: 98 Post(s)
Personally, I prefer the wheels that are on the car in the picture. That said, a black pinstripe will absolutely enhance the car. I think if you ran redline tires on the old Torque Thrusts it would look killer.
post #3 of 5 (permalink) Old 06-11-2014, 07:02 PM
gotyorgoat's Avatar
Here are 18X9 (5.5" BS) with 275/40/18 and 18x8 Fronts (4.5" BS) with 245/45/18. I had to use a bfh and a cutoff wheel to make them fit. Not advised.
The Boss wheel is only available in 18X9.5 with 5" BS or 18X8 with 4.5" BS. The 18X9.5 will not work. Ridler makes a similar wheel with 5.5" BS, but still, 18X9.5 would only work with the perfect backspace.
The only option is a 2 piece wheel with custom backspacing. 5 3/4 or 5 7/8 for a 9 would be best.
It doesn't have nitrous. It has cubic inches.
gotyorgoat is offline
post #4 of 5 (permalink) Old 06-11-2014, 08:04 PM
Agree 100%!
post #5 of 5 (permalink) Old 06-12-2014, 07:17 PM
A pinstripe would certainly break it up a bit and look great regardless of wheel choice. Redlines on your straight spoke T-Thrusts would be a great day two look; but the new wheels could also look good if you lowered the car a bit. Also, if new/larger wheels then the brakes should also look up to snuff.
younggto is offline
Looking For Rally Ii Wheel Advice 151007 1964-1974 Tempest, Lemans & GTO Wheels & Tires 4 08-11-2009 03:00 PM
wheel advice. Dannyz 1964-1974 Tempest, Lemans & GTO Wheels & Tires 2 08-06-2009 10:58 AM
Need new wheel advice arch&69 1964-1974 Tempest, Lemans & GTO Wheels & Tires 8 08-16-2006 10:40 PM
need sensible advice for wheel upgrade BostonF4$ Wheels and tires 2 06-26-2006 11:11 AM
Wheel Hop Advice Mike Kortney Service, Maintenance and Technical Discussion 21 01-26-2006 01:22 AM
